Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-02-2019, 10:04 AM   #1
blazer2007
how would u cut this patch to weld on ?
I trying to fix this rear quarter panel on 78 short box and the rust isn,t to bad ,lots of good metal. If I cut the new patch panel in the green lines I think it would be to hard for me to handle by myself [no help] and get my welds on. I was thinking of cutting the new panel into 3 pieces where the red lines are. Any thoughts or suggestions.
blazer2007 is offline   Reply With Quote
Old 04-02-2019, 10:51 AM   #2
MP&C
MP&C's Avatar
Re: how would u cut this patch to weld on ?
Install the quarter in it's entirety. Spot welds on the flange will cause little to no warping as compared to your weld seams through the middle of a panel..
Robert
MP&C is offline   Reply With Quote
Old 04-02-2019, 11:08 AM   #3
StingRay
StingRay's Avatar
Agreed. It would be crazy to cut up a whole panel like that. That would be a pile of welding, a ton of warpage and and a helluva lot of hammer and dolly stretching to get it somewhat straight again. Put the whole thing on.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-03-2019, 09:55 AM   #4
blazer2007
I was just thinking it would be all floppy trying to get it in the right position
Old 04-03-2019, 10:28 PM   #5
pwdcougar
pwdcougar's Avatar
Originally Posted by mp&c View Post
install the quarter in it's entirety. Spot welds on the flange will cause little to no warping as compared to your weld seams through the middle of a panel..
x2
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1968 2WD GMC Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 04-04-2019, 09:02 AM   #6
Bigdav160
Bigdav160's Avatar
Welding that long green line and right angles would likely result in pucker marks needing filler. The wheel house would be in the way to hammer the welds. Whole quarters are easier than you think.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-04-2019, 09:16 AM   #7
blazer2007
I was thinking if I flange the top piece and use some cleco,s I have a helping hand to cut and test fit the sides until weld up time. This way I can remove the panel and cut and test fit until I,m happy ,sound good?
Old 04-04-2019, 01:05 PM   #8
nsb29
nsb29's Avatar
Why ask for help on how to do it and then do exactly what everyone is telling you not to do your crazy not to use the complete bedside you are going to have a warped up mess believe what they are telling you
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 04-04-2019, 04:39 PM   #9
MP&C
MP&C's Avatar
No, actually sound worse. A flanged seam in an open panel like that is prone to ghost lines in your paint, showing exactly where the seam was placed. See the following video, look for the horizontal line in the paint on this dark green tailgate..
https://www.youtube.com/watch?v=OGhFEfVqxb0
Your best bet is spot welds around the perimeter, as I said above. If you're worried about the panel flopping around, what exactly do you think is going to happen when you cut all the strength out of what you have now by removing the wheel opening?
Robert
Old 04-04-2019, 04:45 PM   #10
pwdcougar
pwdcougar's Avatar
I tried to flange a long patch panel on the side of my Suburban. The flanging tool made the panel wavy as heck.
Old 04-04-2019, 08:49 PM   #11
blazer2007
they don,t make short box bed sides no more
Old 04-04-2019, 09:30 PM   #12
blazer2007
Ok I get the idea , just thought every where I looked said to cut just the rotten panel out and not the good metal. Would be easyier to make a square type patch instead of a jagged piece of floppy metal.
Old 04-04-2019, 11:19 PM   #13
MP&C
MP&C's Avatar
For everyone that tells you to use the smallest patch you can, what do they tell you to do with the weld seam? If they don't mention it, they are not a good source for recommendation.
I prefer to tell someone to instead look first and foremost at where the weld seams will be located and to see if you will have room from the back side for planishing the weld to remove distortion (hammer and dolly) after welding. If there is little access for planishing, perhaps that location is not ideal, look for another. If the panel in question locates welds where the factory put them, and this limits/eliminates weld distortion through the middle of the panel, why would you want that headache of getting the quarter panel straight? If you already have the full bed side, I would only be doing it one way, just like the factory did.
Robert
Old 04-05-2019, 07:24 AM   #14
nsb29
nsb29's Avatar
I give up you can buy them books and send them to school and all they want to do is eat the teacher
Old 04-05-2019, 09:01 AM   #15
blazer2007
That,s too bad, you had lots to contribute to this thread.
Old 04-05-2019, 09:07 AM   #16
blazer2007
Thanks, I,m glad I asked before cutting everything up, I will weld the top close to the top body line where the chrome trim will hide that. On the sides can get in some to planish or dolly.
Old 04-05-2019, 09:30 AM   #17
MP&C
MP&C's Avatar
If you have your heart set on welding in a patch, try to avoid sharp corners. The inside corner tends to amplify the warping (into a pucker) as you're getting shrinking that occurs from two sides in close quarters. A wide sweeping curve would help to curtail those, so the shrinking effects are more equalized from one side of the weld seam to the other. You'll still need to planish the weld to take care of the weld distortion from shrinking, but you efforts will be easier with better consistency. Note I did not say easy, just easier than had you used sharp corners....
What welding method, MIG, TIG, O/A???
Robert
Old 04-05-2019, 08:40 PM   #18
blazer2007
Hopefully last question . When butt welding the panels where I can,t use clamps or magnets ,what would you suggest ,I,ve seen tabs tacked on the inside or outside to keep the panel flat when stitching the weld. I do have experience with butt welding, some with good results and some with bad ,I don,t do it enough
Old 04-05-2019, 09:16 PM   #19
mongocanfly
For everything I couldn't clamp I used magnets...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
