04-09-2019, 10:27 PM | #1 |
Prep cab floor for paint
I'm trying to determine if I just sand the cab floor or need to do other steps to remove the rust on the cab floor. Here's the worst of my cab floor. This the worst area in my truck. Not a show truck just want to take care of this rust and cover the floor up with padding and another rubber mat.
No I don't know how thick (?) it is. Didn't touch it Sunday when I took out the masonite and padding. Thanks!
1984 Chevy Custom 20 $2500 work done on engine and transmission 2010/ less than 1000 miles on it since. Here's my mild build thread, http://67-72chevytrucks.com/vboard/s...d.php?t=783971 |
04-09-2019, 10:38 PM | #2 |
Re: Prep cab floor for paint
On a limited budget, I'd wire brush the heck out it to a shine and epoxy primer it. Then some seam sealer to keep the water out, then Rustoleum paint it.
On a more spendy budget, I'd cut it out, weld in a new piece, and then follow limited budget steps above. Do not apply bedliner or POR 15 as it will only capture the rust allowing it to grow undetected and be a mess to start from scratch. Another inexpensive option might be using a panel bonding adhesive to overlay a fresh piece of sheet metal. There's only one way to fix it correctly as I described by welding in a new piece, but there's a few ways to put a Band Aid on it.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
04-10-2019, 09:30 AM | #3 | |
Thanks again.
