Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-09-2019, 11:32 PM   #1
duramax55
oil canning
i have a question is oil cannig because of to much material or not enough metal . Or can it be either? and how is the best way to determine which one?If it needs shrinking what is the best way to do it other than a shrinking disc? Thanks Denis
duramax55 is offline   Reply With Quote
Old 04-10-2019, 12:38 AM   #2
mongocanfly
Re: oil canning
I had oil canning due to stretched metal...fixed it with a shrinking disc
can also be done with a body hammer and shrinking dolly if accessible to the back
read MP&Cs how-to on the subject....http://67-72chevytrucks.com/vboard/s...d.php?t=647269
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 04-10-2019, 12:45 AM   #3
Getter-Done
Getter-Done's Avatar
Re: oil canning
84 Chevy K-10
paypal.me/Dwayne67CrewCab
Old 04-10-2019, 01:46 AM   #4
72HuggerK20
Re: oil canning
You can fix it by finding a way to heat it and cool it down quickly. The heating can be done with a torch, stud gun, disc, etc. The cooling can be done with a wet rag or a blow gun.
The idea behind it is that you heat up a small area, causing only that area to expand from the heat and the metal surrounding that spot to stay put and not expand. This forces metal into the softer warm spot. Then when you rapidly cool it you don't give the metal that was forced into the warm spot the chance to move back to where it came from. This causes the metal to essentially shrink into the spot that was heated.
72HuggerK20 is offline   Reply With Quote
Old 04-10-2019, 09:11 AM   #5
MP&C
MP&C's Avatar
Re: oil canning
Do you know what caused the oil canning? Don't jump in with a shrinking disc until you can determine the cause. Did the panel experience some body damage, or have you been welding on something? Different method of repair depending on the cause, so yes, to answer your question it can be cause by either too much metal or not enough.
I would suggest reading this first for the theory....
http://www.67-72chevytrucks.com/vboa....php?p=7305501
….and then read this thread in its entirety for a real world application, where welding was the cause... and planishing (stretching) was the corrective action.
http://www.spiuserforum.com/index.ph...l-canning.5502
It's hard for anyone to give you accurate repair advise tailored to your exact situation without more information about what you have. Pictures would help, a video of you cycling the oil can would be even better.
Robert
MP&C is offline   Reply With Quote
Old 04-10-2019, 11:24 PM   #6
duramax55
Re: oil canning
MP+C thanks for the info i am trying to fix a 55-2 hood that had previues damage and then a area that was pushed in by someone siting on hood i think. The person that fixed the previous damage used heat and very heavy hamer work on it. Plus got some sandblast warpage. i think it is almost imposible for me to fix, would need more experiance. But im still trying if nothing else ill gain experiance. i would post pics if i could might have to try again.
Old 04-10-2019, 11:38 PM   #7
mongocanfly
Re: oil canning
heres how to post pics....http://67-72chevytrucks.com/vboard/s...sting+pictures
Mongo...aka Greg
Old 04-11-2019, 12:11 PM   #8
MARTINSR
MARTINSR's Avatar
Re: oil canning
If it's from someone sitting on the hood there is likely buckles that are keeping it oil canning.
Here is the "Basics of Basics" on the subject.
Basics of Basics” Flat panel repair
By Brian Martin
When you have a large flat panel that is flexing the first thing you need to do is find out why. Sometimes you can stop it, other times you can’t. But if you can stop it, you’ll have a much easier time with the body filler work. Hoods, decklids, and the roof are particularly difficult because the heat and weight of the plastic filler can have an effect on the metal. The good news is many times it is very easy to repair. First off, there is no such thing as a “flat” panel. All panels that appear flat actually have a slight crown or gentle bow up in the middle. Go to a flat panel and lay a straight edge across it. You will see that the straight edge in not touching the panel at the on the outer ends. If the panel were perfectly flat it would appear to the eye to be concave. It would also have no “body” and flex very easily. This is the problem with your large flexing panel; it has “lost” its crown and is now weak and flexible. The first place to start your search for a culprit is under the panel. Many panels have inner structure that supports the outer skin. When the outer panel has been damaged the inner structure was bent down along with the outer. This inner structure can be in the form of just a simple inch or so wide support running across the panel to the complete support by a stamped panel that goes covers the underside of the panel. These full inner structures can commonly be found on hoods and decklids. The inner structure can sometimes be bent down, causing your flexing. It usually is very close to the outer skin, with just a thin layer of a foam or urethane adhesive. It may have small “dollops” of this foam or adhesive that has been squished between the inner structure and outer skin or even a thin piece of tarpaper. You can push up on these low spots to return it to supporting the outer skin, as it should. But it is difficult because you can’t push it past where it needs to be. On this particular type of damage, the inner structure would need to go past the correct shape and then “relax” back down to where it belongs. It can’t do this of course because the outer panel is there and limits the inner structure from going up where it needs to go. Just as with looking at the “big picture” when you look at any dent, you need to search for a kink or bend that is holding the inner structure down in that area. If you apply pressure up on the low area and tap out these kinks, you may get it to stay back in shape. If these methods don’t get it back up to support the outer panel properly, you will need to “shim” between the two panels to get the outer panel up where it belongs. This can be done with sheet of tarpaper or more adhesive. As a last resort a thin piece of wood like a paint stirring stick can be used. Of course, this is a little on the funky side but if you are haven’t been able to correct the problem, something has to be done. What you have to watch out for is applying too much pressure in one area. If you were to force a piece of wood in there, you will likely be making a high spot on the outside. That would just give you in a whole new problem. Sight down the body lines that are nearest the low, “oil canning” , or just plain flexing area. A body line is effectively the “edge” of the panel. Those crowns in the flat panel that I mention end at the body line. So each area in between the lines is sort of like an individual panel. Look to see if the body line is low, it may be holding down your panel. If it is, you need to push it up. To help you determine how straight the line is sometimes you can use a metal ruler as a “straight edge”. How can this be done on a crowned panel you ask? A metal carpenters yard stick will bend very easily, right? So what you do is lay the yard stick on it’s back against the panel and apply a little pressure on the outward edges low area where the metal is OK. You will then have a “curved straight edge”. I have a drawer with a number of these metal or aluminum rulers in it and find them very useful. I treat them like rice paper and they will last a lifetime. So lets say that you have found that you have no low spots in the body lines or there were one or two and you repaired them. Now you have to look for something else that is holding the panel down. This can usually be found in the form of a “crown” or “brow”. When you put a dent in any panel the metal has to “go” somewhere. All panels have this crown, right? So as an example picture a metal rod that is 3 feet long. This rod has a slight bend to it. The center of the rod is up from the ends about three inches. If you were to push down on the center, the rod would get “longer”, right? So, if the ends of the rod were clamped in vices, the “extra” rod would force the areas on the sides of where you were pushing to go up. You panel does the same thing only on a much smaller scale. Most brows will be found on the outer edges of a panel, this includes of course at the edge of the body line. They are VERY common around the outer edges of a roof. Search around the outer edges of ANY bent roof and you will find them. The brow or crown is a U, C, L or even I shaped high spot. In the center of that curved high spot is a low spot, sort of like a “pocket” in the brow. Just one or two of these will make a panel, especially a large panel look like a cotton sheet! What you have to do is to push up on that low spot while tapping down on the brow. When I say “tap” I mean TAP. Just the weight of the hammer bouncing off the brow will do it sometimes. Use a large VERY flat body hammer or a flat body spoon for this repair. If you are careful you can repair these brows with little to no plastic filler. Just take you time and keep checking the area with a block with sand paper or a vexon file if you have one for low and high spots.
Now, if you simply can eliminate the brow and low spot, you have won the battle. If it takes some plastic filler, so be it, you have given the panel it’s strength back and that is what matters.
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
