Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-31-2018, 09:09 PM   #1
Lostatsea
New harness problems
Just finished American auto wire complete harness on my 67 c10. Only thing that works are headlights/high beams and the engine will turn over. Nothing else is working or has power. Iím really discouraged and overwhelmed on where to even start. Any ideas? Thanks guys
Lostatsea is offline   Reply With Quote
Old 12-31-2018, 09:33 PM   #2
Lostatsea
Re: New harness problems
Found the first foolish mistake. Did not have any of the fuses installed. I now have turn signals. Still nothing on the dash cluster. Does the connector that plugs into dash cluster only go one way?
Old 01-10-2019, 06:37 PM   #3
notsolo
notsolo's Avatar
I believe the dash cluster plug is 1 way, on mine...72...classic update...harness dash wiring is slightly different for oil pressure vs just lights..Different pages on the instruction sheet...check all your grounds, make sure you have solid clean contact for Frame, cab, front and back sheet metal....should also be a ground clip for dash bezel....also .Welcome aboard.
notsolo is online now   Reply With Quote
Old 01-10-2019, 09:17 PM   #4
04ls1gto
Grab a test light and start checking things. You'll figure it out
04ls1gto is offline   Reply With Quote
Old 01-11-2019, 02:33 AM   #5
First c10
First c10's Avatar
I am days away from starting my install. I hope you figure it out. For me it’s always a simple little thing I over looked.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1968 K10 LWB Dark green my son calls it "THE HULK Jr"
Hulk Jr *SOLD*
1970 K20 LWB project the Hulk build
HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
GO GO!!!
First c10 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
