Old 03-20-2017, 06:04 PM   #1
Ramiro0727
Temp gauge reading low
Just recently finished installing a rebuilt SBC 350 with aluminum heads. I re-wired the whole truck from front to back. I noticied that the temp gauge reads low. At first the temp gauge was pegged all the way to hot. I grounded the bottom terminal on the temp gauge and the gauge started working but it reads low. Could the temp sensor be bad or the temp gauge is bad? The temp gauge is brand new.
Thanks,
Ramiro
Ramiro0727 is online now   Reply With Quote
Old 03-20-2017, 06:21 PM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Temp gauge reading low
I'm thinking the sensor and gauge are not compatable. Where is the sensor mounted and did it come with the temp gauge?
RUBBER DOWN AND HIT THE ROAD!!!
my56chevytruck is offline   Reply With Quote
Old 03-20-2017, 06:24 PM   #3
74baggedbug
Trace the wire from the sensor to the gauge.. make sure it's not grounding out somewhere
74baggedbug is offline   Reply With Quote
Old 03-20-2017, 06:41 PM   #4
Ramiro0727
My56chevytruck the sensor is mounted on the drivers side on the block of the engine
Old 03-20-2017, 06:45 PM   #5
Ramiro0727
74baggedbug I will trace the wire from the cluster to the gauge to make sure its not grounded. It's a new wire I added when I re-did my dash cluster plug.
Old 03-20-2017, 06:49 PM   #6
my56chevytruck
The mounting is correct but is that sensor and gauge compatable? In other words, did they come together as a unit? Also, like others have said, check the grounding. Any possibility you have another gauge you can hook up to check against this one?? Nice engine.
Old 03-20-2017, 08:13 PM   #7
RGT
What temp. thermostat do you have in the engine? Maybe it is reading correct, mine only sits a little to the right of that second line and never points straight up and down even on a hot day...
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering.
RGT is offline   Reply With Quote
Old 03-20-2017, 08:19 PM   #8
Ramiro0727
My56chevytruck I bought the sensor from our local parts store. The gauge I got at Brothers truck. I still have the old gauge I replaced with the new one. Than you. Here is a better pic of the engine.
Old 03-20-2017, 08:24 PM   #9
Ramiro0727
RGT not sure what temp thermostat my son put in it. When it really warms up it gets to about the 2nd line. Also the sensor for his electric fan is 180 degrees and the fan turns off when it gets to 160 degrees.
Old 03-20-2017, 08:30 PM   #10
davepl
davepl's Avatar
I believe the original is Delco #G1852, so anything compatible with that should work.
Standard Motor Products TS6 or TS6T
Airtext 1T1053
Do you have a part number for the sensor you used? I can check to see if it's compatible with the factory gauge just to make sure.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-20-2017, 08:37 PM   #11
garyd1961
Looks about right for these trucks. Mine ran about the same with a 180 thermostat. Back in the day most every one of these trucks I rode in ran about the same.
I put a 195 thermostat in mine and now it runs a little to the right of the first mark but I'm running a vortec engine which was meant to run a 195. I may just go back to the 180 for the summer though.
garyd1961 is offline   Reply With Quote
Old 03-20-2017, 09:53 PM   #12
chevy72blu
chevy72blu's Avatar
Looks about right to me? Every one of these trucks I've owned will read right at that line or close to it. My LS has I believe a 180* stat (fans kick on at 200) and its verified by my OBD2 scanner right next to the gauge (just to the right of the line).
Check your T-stat. You may have a 165* or something and its reading correctly.
Also, its not like these gauges provide much info. So long as you know what is normal - and can tell if its overheating, the gauge is doing its job IMO.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 03-21-2017, 01:44 AM   #13
Ramiro0727
I asked my son about the thermostat. He can't remember temp the thermostat is rated for. I'll assume everything is fine with his temp gauge where it reading. Than you all for your help.
Ramiro
Copyright ©2000 - 2018, vBulletin Solutions Inc.
