05-25-2016, 12:39 PM | #1 |
Stereo speaker location suggestions
I am looking for any suggestions as to where I can mount some stereo speakers in my '70 C10.
PO mounted them in cutout on the driver and passenger side kick panel walls (see photo). Unfortunately I do not believe there is enough depth to mount some decent 5 1/4 sized speakers. I tried the plastic molded kick panel speakers from Brothers but the speaker sticks out too far and it interferes with the parking brake when depressed. I thought about installing in the door panels on the bottom metal area below the upholstered door panels.? My gas tank is still behind seats so no room there....Any thoughts?
1970 C-10 CST, LWB, 402/400, A/C |
05-25-2016, 01:32 PM | #2 |
Re: Stereo speaker location suggestions
dont cut your doors , I dont use my vents , so I got 5x7s and put them were the vents were , I used these behind them
http://www.ebay.com/itm/XTC-5x7-Inch...kAAOSwhwdVUhsk
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
05-25-2016, 01:35 PM | #3 |
I use then molded ABS kick panel pods. To get my parking brake to clear the speaker, I simply removed the pedal from the arm and re-welded the pedal back on farther to the right. I had to modify the rubber pad and metal trim a little to fit back over the pedal, but it looks stock and works great. BTW, I added a little triangular brace under the pedal to give it more support because the arm is now pretty much under the left edge of the pedal.
05-25-2016, 02:05 PM | #4 | |
I'm pretty frustrated that my doors have a badly cut speaker hole in each of them. I like the vent idea and have considered that myself. I've also seen them squeezed up in the dash...depends how you have your duct work in and what you've got for a glove box. |
05-25-2016, 02:30 PM | #5 |
forgot to add they sound great in that location with the enclosures
05-25-2016, 03:02 PM | #6 |
67chevelle-
never thought about putting 6x9's in the vent holes and just not using them. Of course, I just finished removing the vent doors out and installed new gaskets but haven't reinstalled them yet. How did you finish the kick panels...carpeting? plastic covers? Possible to send me a picture? I'd like to see how it looks! Thanks for good idea!
05-25-2016, 04:19 PM | #7 |
I'm curious...why would you recommend not to install in doors?
05-25-2016, 04:22 PM | #8 |
Don't cut the bottoms of the doors, but do cut the door PANELS. This is a great place to install speakers as they are up higher and if you change your mind, a new door panel hides the install. Or even better, but repro plastic panels and cut them for the speaker saving your originals. Here is a link to my write up:
http://67-72chevytrucks.com/vboard/s...d.php?t=659786
05-26-2016, 02:17 AM | #9 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-26-2016, 07:12 AM | #10 |
Actually, '72 is the exception and not just for quality of repro part since the panel is not flat. In my '72 Jimmy I made 1/4" plywood panels covered with vinyl and used 67-71 armrests instead of the integral '72 parts.
But he said his truck was a '70 so good to go. Either way, this is the most cost effective and cleanest way to install a sound system that is minimally invasive and easily covered up if you want to revert to stock.
