Old 07-31-2020, 10:16 PM   #1
bigmoe
bigmoe's Avatar
Side trim hole location?
My 65 Fleetside never had side trim and I never drilled any prior to paint. I plan to 3m the trim on as I’ve seen on this forum. The trim strip was not painted on either and I plan to use a vinyl stripe between the trim. If someone could give me the vertical measurements from the crease down to the top and bottom holes I’ll run the vinyl trim width at that location. Thanks.
bigmoe is offline   Reply With Quote
Old 07-31-2020, 10:52 PM   #2
bigmoe
bigmoe's Avatar
Re: Side trim hole location?
These are the holes I want to locate but not actually drill so I know where to put my stripe.
Old 08-01-2020, 08:17 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Thread on measurements - http://67-72chevytrucks.com/vboard/s...d.php?t=517895
Old 08-01-2020, 09:03 AM   #4
bigmoe
bigmoe's Avatar
Is it on this one? I'm sorry I don't know if it's my monitor but I can't read the numbers. Do they use the crease to measure from?
Old 08-01-2020, 09:37 AM   #5
bigmoe
bigmoe's Avatar
another
Old 08-02-2020, 02:55 PM   #6
bigmoe
bigmoe's Avatar
I got some info from a guy who measured his holes for me. He says the top row of holes is 1 7/8" down from the crease to center of holes. The second row of smaller holes is 2 1/2" down from that, center to center. So the stripe is 2 1/2" wide.
Old 08-03-2020, 05:14 PM   #7
tigerburns
Active Member
tigerburns's Avatar
I plan to do the same exact trim addition with the 3M and vinyl stripe to my '65 one day, so this thread will come in handy one day when I need the measurements.
Thanks, and Good Luck!
tigerburns is offline   Reply With Quote
Old 08-03-2020, 08:47 PM   #8
bigmoe
bigmoe's Avatar
It will take some measuring and figuring, especially where the front of the stripe curves up but I have the measurements I need to get started.
Old 12-11-2024, 12:26 PM   #9
val1gonzales
This might be the one you need to help you as well.
https://67-72chevytrucks.com/vboard/...d.php?t=752529
val1gonzales is offline   Reply With Quote
Old 12-11-2024, 03:08 PM   #10
bigmoe
bigmoe's Avatar
Got mine done quite a while ago but that link will be helpful to others in the same predicament.
Old 12-11-2024, 08:05 PM   #11
MT65
Smile Re: Side trim hole location?
Thanks to all that replied , now just deciding tape or holes…..
MT65 is offline   Reply With Quote
Old 12-11-2024, 09:31 PM   #12
bigmoe
bigmoe's Avatar
In nearly 4 years mine has held very well. I did have to remove one long door molding because I had put it on backwards.(one end is thinner to allow clearance when opening the door). To remove I ran strong fishing line behind it. I did drill one hole per side for the front spear.
Old 12-11-2024, 10:12 PM   #13
jayoldschool
Moderator
I did holes with the OEM clips. Worked perfect, nothing has fallen off in the many years since.
jayoldschool is offline   Reply With Quote
Old 12-12-2024, 10:21 AM   #14
rbruno68
I have looked at that drawing from the assembly manual a bunch of times. I understand the measurements for the bed for instance are taken all from line "25". But, I have yet to see how they established line "25". I see that people have measured from the crease line to mark the holes, but no measurements that I have seen show how the factory established line "25". I plan to add these to my 63 as well.
Rob
rbruno68 is offline   Reply With Quote
Old 12-12-2024, 11:42 AM   #15
MT65
Angry Re: Side trim hole location?
Doesn’t that just twist your butt when the factory leaves out an explanation on a measurement, like they pulled it out of thin air
Old 12-12-2024, 12:01 PM   #16
MT65
I’m having an idiot attack, know that I saw a section on using the 3m tape, now can’t find it, I have some I used on another project, 3m trim tape , bout an inch wide and its black, got it from my local automotive paint store…if someone has the part number for the tape, would appreciate it…thanks in advance
Old 12-12-2024, 09:26 PM   #17
bigmoe
bigmoe's Avatar
3M VHB 5952
https://67-72chevytrucks.com/vboard/...d.php?t=597891
Old 12-13-2024, 11:35 AM   #18
MT65
Thank you, I’ll see if its the same stuff I have in my shop, or get it for sure..
