03-06-2015, 03:27 PM | #1 |
Lowering my 1970 C20
I am new to the board and have really enjoyed looking at everyones builds and the wealth of information found here. I am just starting a build on this truck and one of the first things I would like to address is lowering & converting to 5x5 lug and front Disc. I am hoping to drop front 5 1/2 " and possibly 7" in Rear.
I have some questions maybe you all could help me with: Can I use a C10 Drop spindle kit on a C20? What would be best way to achieve this drop? Suggestions? Advice? Thank you in advance for any and all help. |
03-06-2015, 03:35 PM | #2 |
Re: Lowering my 1970 C20
welcome from TEXAS!!!!!
i can't help ya with your drop question but you might post it the suspension section for more help. and also wanted to say
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-06-2015, 03:40 PM | #3 |
I agree on the pics, but unfortunately I live in Maine and we have had 127" of snow this year! Preparing for spring Sorry didnt see suspension thread.
03-06-2015, 04:12 PM | #4 |
I went with a 6 inch rear drop and 4 inch front drop. Used two inch lowering blocks and four inch shorter springs on the rear along with a bent pan hard bard for clearance and a c notch. The front was 2.5 inch drop spindle and 1.5 inch shorter spring.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
03-06-2015, 04:17 PM | #5 |
snow? what is that.... lol we had a pretty cold morning this morning, got down to blustery 34*, burrrrr
03-06-2015, 04:23 PM | #6 |
Did you use a C10 Drop Spindle? Did you convert your Bolt Pattern to 5 lug?
03-06-2015, 10:12 PM | #7 |
No 5 lug for me yet. I have 5/3 lowering so far. I used springs from GMC Paul's, relocated shocks and trac bar from CPP. Good luck!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
03-06-2015, 10:34 PM | #8 |
Hey rodzilla67 ...
to the forums and from Ohio. I will move this to the "Suspension" forum where you might get addition help.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-06-2015, 10:52 PM | #9 |
03-06-2015, 11:06 PM | #10 |
03-07-2015, 10:10 AM | #11 |
As I commented in your other thread, ECE is the only company that will let you keep all the rest of your suspension stuff and run 5 lug brakes with their spindle.
Scroll down here and see the C20-C10 spindle. http://earlyclassic.com/catalog.aspx...ry=New%20Items And here is a good link that covers many of the questions you have. http://67-72chevytrucks.com/vboard/s...d.php?t=662011
03-07-2015, 02:06 PM | #12 | |
Thank you for reposting this for me. |
03-08-2015, 08:58 PM | #13 |
Just wondering if I can use C10 spindles on a C20? Are they that different?
Was also looking at the possibility of: http://www.ebay.com/itm/391054955572...%3AMEBIDX%3AIT |
03-09-2015, 02:22 AM | #14 | |
Idk about spindles though if c10=c20 Basic 12" 5x5 http://www.mcgaughys-suspension.com/...ys-part-63156/ 63-70 drop spindle used that year ball joints and tie rods. http://www.mcgaughys-suspension.com/...ys-part-63173/ 13" upgraded 5x5 kit drop spindle included http://www.mcgaughys-suspension.com/...ys-part-63151/ |
03-09-2015, 04:19 PM | #15 |
Tree-50, thank you so much for the links and tips. If I can figure out if I can use C-10 spindles on a C-20 I'll be ready to go! lol
03-10-2015, 08:19 PM | #16 |
Rodzilla67,
Lots of info on front changeout. What is your plan on converting the rear end to 5 bolt? |
03-10-2015, 09:35 PM | #17 |
03-10-2015, 09:50 PM | #18 | |
67-72 parts collector,…
3/4 ton lower a--arms have a larger balljoint hole. You will need 1/2 ton lower a-arms and you will have to switch to 1/2 ton balljoints and outer tie rods. Simpler choice is to use the "3/4 to 1/2 ton CONVERSION spindles" offered by ECE.
03-10-2015, 09:51 PM | #19 | |
03-10-2015, 09:52 PM | #20 | |
Best option to convert an 8-lug truck to 5-lug
03-10-2015, 10:14 PM | #21 |
Ty Lolife. Awesome info!
05-08-2017, 08:59 PM | #22 |
Where did you find the 2-inch lowering blocks and did they come as a kit with the longer u-bolts?
05-08-2017, 09:11 PM | #23 |
Diggin The SquareLife
Just use google man not that hard
05-08-2017, 09:20 PM | #24 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=454824 Here's a couple good threads to look at. Member way2lo2 is a good source for lowering blocks and u-bolts.
05-08-2017, 10:16 PM | #25 |
I got mine from CPP. They did include the longer U bolts and nuts.
