Old 01-07-2019, 11:19 AM   #1
andyh1956
Traction Bars For Pickups
I am going to need some kinda traction aid for a 2wd pickup. being that trucks are spring over traction enhancing becomes more of a challenge than a spring under setup.
I came across this setup on the web & it looks well thought out from a street ride point of use. However it of course is configured for a spring under setup. If this photo was flipped spring over I can't see anything that would stop it from working. In the photo as the axle tube rotates CCW under acceleration the bar is pushed forward which rotates the bracketry CCW imparting pressure to the top of the spring w/ the roller.
Reversed it should still do the same thing as the bar would be PULLED to the rear & push roller to the spring. However I'm sure the spring hangers are gonna have something to say about using this setup as drawn...
Anybody here have any kinda traction aids on their trucks using a spring over configuration?
thanks
andyh1956 is offline   Reply With Quote
Old 01-07-2019, 01:46 PM   #2
sweetk30
sweetk30's Avatar
Re: Traction Bars For Pickups
http://www.calvertracing.com/store/c...kit-p-184.html
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-07-2019, 06:25 PM   #3
andyh1956
Yep, won't work on a spring over...
Old 01-07-2019, 08:13 PM   #4
82C10step
They make them for spring over and spring under.
82C10step is offline   Reply With Quote
Old 01-07-2019, 08:20 PM   #5
sweetk30
sweetk30's Avatar
and i made sure to link the spring under for flip kit . .
Old 01-07-2019, 08:26 PM   #6
homemade87
I have this style on my 82 . There is a kit if you do a flip . http://www.calvertracing.com/store/c...kit-p-184.html which I do not have . I have the reg set .
Also this is going to take care of the wheel hop if you are experiencing it . But it will not take care of tire spin for the lack of a good traction tire . It is some better and will help some but don't expect the street tires will plant on the road .
homemade87 is offline   Reply With Quote
Old 01-08-2019, 12:41 AM   #7
andyh1956
I thought the text of my post made it clear that spring under or "Flip KIt" bars wouldn't work.
Thanks for pointing me in the right direction though...
Old 01-08-2019, 12:45 AM   #8
andyh1956
I called them late today & tomorrow they will send me a line drawing of what they think I need in a spring over configuration.
I only got to look at this at lunch time today & before I got to the calvert racing site the phone co dug up our cable out front- along with our water line so toilet wouldn't work either...
Are any yall using these & if so how do you like them?
Thanks!
Old 01-08-2019, 06:45 AM   #9
82C10step
I have them on my 82. On drag radials it does 1.5-1.6 60fts. I can get it to leave on the street pretty decent too. Haven't run regular street tires on it tho.
Old 01-08-2019, 01:15 PM   #10
sweetk30
sweetk30's Avatar
oooppps miss read . . . but sounds like you got it now . and for others they show reg leaf over kits for stock setups .
Old 01-09-2019, 07:46 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Cal-tracs have an excellent reputation all across the country. If you go to any drag strip on any weekend, almost any leaf sprung rig that hooks hard will be runnin Cal-tracs. They are worth every penny.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-09-2019, 10:30 PM   #12
andyh1956
Hey I wanna thank you boys for helping me. Got hold to Calvert Racing today & they said they either had or would make anything I need!
All I need on my end is a tape measure!
