01-21-2019, 12:27 PM | #1 |
Smaller power brake booster for 69 C10
Really tired of working around the factory brake booster. Any thoughts on a smaller booster or an alternative
Posted via Mobile Device |
01-21-2019, 12:35 PM | #2 |
Post Whore
Re: Smaller power brake booster for 69 C10
Go with a small dual diaphragm booster if space is a issue....hydroboost is another option
01-24-2019, 08:27 PM | #3 |
I think my 69 had an 11" booster which has an area of 95 square inches. So, if you go the dual booster route, 8" is very close to that. Do not use dual 7", or you will lose 20% of the stock area. A dual 9" would work well with a heavy truck or a low vacuum cam.
However, the M/C is gonna stick out further into the engine compartment, unless you get a setup that uses a shorter firewall-to-booster mounting bracket than stock. I'd call Master Power Brakes to see what they suggest. https://www.mpbrakes.com/booster-mas...stermaster.asp
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-25-2019 at 10:14 AM. |
