01-05-2018, 01:37 AM | #1 |
Utility Buckets w/ Console
Does anyone know if you can squeeze in the console between the utility buckets?
Or if not what do people run for consoles if they have utility buckets? Thanks in advance. |
01-05-2018, 01:39 AM | #2 |
Re: Utility Buckets w/ Console
Ok well i DID search for maybe 30 mins before posting but of course I found this wonderful post/Pic right after
http://67-72chevytrucks.com/vboard/s...0&postcount=23 |
01-05-2018, 06:46 AM | #3 |
I had a 71 with utility buckets and a console I'm assuming it came that way.
01-05-2018, 09:10 AM | #4 |
My '70 with utilities has one. Unsure if it came from the factory with it, but I had one and was able to it jamb in, it's a tight fit and I didn't even bother with bolting it down
01-05-2018, 09:35 AM | #5 |
Mine Fit. (see pic) and I have couple different 70's consoles but I recently chose to run a hot swappable configuration with new electronics (see other pic).
01-05-2018, 11:09 AM | #6 |
I'm using utility seats with console. It does fit, but it is tight. Biggest issue is the side of the passenger seat rubbing the console when you tilt it forwards.
To me it's worth it. I prefer the look and comfort of the utility seats better. |
01-29-2018, 11:24 PM | #7 | |
Michael |
02-09-2018, 03:40 AM | #8 |
So glad you posted this, I was just told by a friend 3 days ago this wouldn't work. I completely re-did a console for my blazer and haven't had the chance to redo the interior and was crushed when I was told this wouldn't work. Glad to see it will fit and you provided a good link, thanks!
02-16-2018, 01:59 PM | #9 |
watching
02-16-2018, 05:37 PM | #10 |
I had a console in my 71. You can elongate the mounting holes in your seat tracks and brackets sideways a bit to move each seat towards the door slightly to gain a bit. Just have to remember to hold the back of the passenger set towards the outside when you tip it forward.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-17-2018, 08:48 AM | #11 |
Just to be clear on consoles, they only came with the CST seats. Utility buckets were standard with buckets/no console was the option for base trim. These seats came with buckle holders screwed to the inner side bottom edge.
The fit question has already been answered, yes but tight squeeze.
02-17-2018, 11:20 AM | #12 |
Right. Actually a driver only utility was base. In my 71, I put a later cup holder console in with utility buckets and I'll do the same with the 69. I'm a coffee drinker and got to have a place for my Tim Horton's (you guys down south might someday be lucky enough to have a cup of Tim Hortons coffee) When I head south to my son's place in NC the furthest south I have found one is in West Virginia, and then it is just a little express one in a gas station convenience shop.
02-17-2018, 11:32 AM | #13 |
Here is my 71 Utility/Console
02-17-2018, 05:00 PM | #14 |
hickey is smaller and fits better
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
02-18-2018, 02:24 AM | #15 |
Rsavage where'd you get the houndstooth utility bucket upholstery?
Gary - Just had to do a search for that console. Never seen one before! |
02-18-2018, 07:28 AM | #16 |
The upholstery guy I use ordered it and made the seat covers for the front buckets and rear seat. I had a softopper on that Blazer and I figured it would be a lot cooler on behinds if the top was down (as opposed to black vinyl).
02-18-2018, 10:42 AM | #17 |
I have one never put with the utility seats but did try with custom seats is to narrow and don't look right. They come up on the board haven't seen one in a while.
02-18-2018, 03:49 PM | #18 |
Gary, can you post a pic of your hickey console? I have two but might be con-ferr vs hickey. Mine has a fold up seatback and key lock. Hickey had a latch vs key
02-20-2018, 02:43 PM | #19 |
Ok might have to contact some local shops. My Blazer is getting painted hugger orange and I'm going with a lighter interior color. Trying to see what's out there...
