Old 01-25-2019, 05:55 PM   #1
Classics Fan
Rochester Quadrajet 4v Solenoid
I have a 1971 Jimmy with original rebuilt 350 and A/C. Questions about the carburetor solenoid: first, is this an idle stop to prevent dieseling, or an idle increase for the A/C to prevent low idle stall?
When I start the engine, the solenoid plunger extends (sometimes, not every time) for a few moments then retracts. This action seems to happen irregardless of whether the A/C is in the or off position. The A/C belt was removed by the PO and I have never replaced it so I’m not certain whether the air works or not.
Where does the solenoid get its power, and what possible causes are there for it to only work momentarily, intermittently? I have the idle speed set using the designated screw. If the solenoid is for idle stop, then why is there also an idle speed screw?? Thanks in advance for any insight to help clear up my confusion.
Classics Fan is offline   Reply With Quote
Old 02-04-2019, 09:36 PM   #2
Classics Fan
Re: Rochester Quadrajet 4v Solenoid
Bump. Any Rochester gurus around? TIA!
Old 02-05-2019, 09:10 AM   #3
jaros44sr
jaros44sr's Avatar
I would call cliff rugles, googled it and all kind of info
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-06-2019, 07:00 PM   #4
Classics Fan
I did my Google research before posting here and did again, but haven’t seen anything that answers my questions. Thanks for the Cliff Ruffles lead.
Old 02-06-2019, 08:10 PM   #5
jaros44sr
jaros44sr's Avatar
sorry you misunderstood me , I was only referring to get the addy for Rugles. You might PM green monster, when I was working his truck we were discussing that solinoid, we didn't get very far
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2019, 10:01 AM   #6
pound41
If you are talking about the plunger type solenoid that hooks on the carb with a bracket. I don't think that is the anti dieseling for the AC. I say that because I have 2 1971 Blazers. #1 doesn't have AC and it has the carb based solenoid but who knows.
Blazer #2 has AC. I will have to look and see if it has the carb based solenoid.
the fan switch and blower motor would only work on med.Which drives me crazy I checked all the grounds. Didn't fix the problem so I started replacing everything Heat and AC related. On my blazer down near the Cig lighter behind the dash it has a what I will describe as a relay mounted. The relay is very similar to the relay for the blower motor. The wires are different though. Anyway I found in my research that was a anti dieseling relay that was supposed to engage/disengage the clutch under load etc. This was a few years ago when I worked on it
pound41 is offline   Reply With Quote
Old 02-07-2019, 02:01 PM   #7
Classics Fan
From everything I’ve been able to find and read on this subject, the solenoid is EITHER an anti- dieseling device (always activated with ignition “on” and deactivates with ignition “off”) or is only activated when AC is on. As an anti-diesel it allows the butterflies to fully close when the ignition is turned off. As an AC function it activates only when AC is turned on to increase idle speed to prevent low RPM stalling. This understanding and erratic behavior on my truck tleads me to the questions in my original post. If your non-AC Blazer has the solenoid as original equipment it must act as an anti-diesel. If you have the solenoid on both vehicles and are inclined to investigate further, let me know what you find! Anti- diesel on both, or only the non-AC and anti-stall on the other, or ....? My Jimmy runs great but my curiosity is piqued.
Old 02-13-2019, 11:51 PM   #8
JackB
The solenoid is 1971 only and its called a Combination Emissions Control (C.E.C) valve. It has electrical and vacuum connections. In addition to the valve (solenoid) there should be two relays on the firewall near the master cylinder.
A google search for 1971 CEC should answer any questions about how the system works. Most of the time its just removed.
JackB is offline   Reply With Quote
Old 02-14-2019, 11:22 AM   #9
Classics Fan
I think you hit the nail on the head. Thanks for the info!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
