04-15-2014, 12:49 AM | #1 |
4l60e problems?
Just got a 90 Chevy 4x4 and trans is acting up not wanting to shift but still pulls strong is this a solenoid problem or do I need to find a trans?
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops |
04-18-2014, 09:38 PM | #2 |
Re: 4l60e problems?
Are you sure that it's a 4L60E and not a 4L60? The E is electronically controlled for shifting.
It could be the transmission controller, or something as simple as dirty/low/wrong ATF. If you haven't changed the ATF yet, I recommend replacing the filter and ATF, many people neglect their transmissions.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-18-2014, 09:44 PM | #3 |
Re: 4l60e problems?
The plastic governor gear is also a common problem that will cause them to not shift out of 1st gear.
I changed one out once and got it to shift from 1st to 2nd (which it wouldn't do before) but found out that the trans was bad anyway and had to have it rebuilt. |
04-23-2014, 03:08 AM | #4 |
Re: 4l60e problems?
I just got the truck it leaks bad you can tell someone has been init it has a new pan gasket clean fluid it will shift from 1-2 ok from 2-3 is real hard and that's all its got
