Old 02-02-2018, 11:10 AM   #1
808_67C10
808_67C10's Avatar
Putting steering wheel lock plate back in - help
Anyone have any tricks for putting the steering wheel lock plate back in?
I pulled it apart to replace my ignition lock cylinder and now I am having a difficult time pushing the plate past the ridge to install the C clip/lock. That spring under it aint no joke or, I am losing my strength in with age!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 02-02-2018, 11:15 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Putting steering wheel lock plate back in - help
I use one of these:
https://www.summitracing.com/parts/o...SABEgKIRfD_BwE
They are sold at most parts stores.
95 S_Trucker is offline   Reply With Quote
Old 02-02-2018, 11:15 AM   #3
KrazyRay
KrazyRay's Avatar
There is a tool that compresses the plate to install the ring. Without that tool, its a nightmare to fight.
KrazyRay is offline   Reply With Quote
Old 02-02-2018, 11:39 AM   #4
Danmcg
There is one or 2 wide splines on the shaft that needs to match the teeth on the plate.
Danmcg is offline   Reply With Quote
Old 02-02-2018, 12:12 PM   #5
kwmech
Yup, there is a master spline. You need the tool, it pulls up on the shaft along with pushing down the plate
Old 02-02-2018, 04:37 PM   #6
808_67C10
808_67C10's Avatar
Thanks everyone... I wrestled it last night for about 30 min and 2 beers (beer strength) and could not get it in far enough to set the clip. I will check with my local parts store for the tool. Figures there is a special too for EVERYTHING.
Thanks!!!
Old 02-02-2018, 08:02 PM   #7
chrismoore701
chrismoore701's Avatar
Loan a tool from autozone. That’s what i did. Worked like a charm
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-02-2018, 09:30 PM   #8
808_67C10
808_67C10's Avatar
I live on the Big Island of Hawaii.... No Autozone here. We have Oriellys and Napa... Oriellys had for loan but, it wouldn't be back till tomorrow so, I just went to Napa and got one for 13 bones and some change.
I appreciate all the help!!!
Old 02-02-2018, 10:24 PM   #9
chrismoore701
Done and done
Chris
Old 02-11-2018, 07:18 PM   #10
Pontiac1976
Pontiac1976's Avatar
Or make your own tool [IMG] [/IMG] http://bowtieguy.proboards.com/thread/1227/tilt-column-tear-repair-renew
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
