12-18-2018, 12:52 AM | #1 |
TH400 rebuild kit question
I'm planning to buy a shift kit from Transgo (400-Pro). They don't sell rebuild kits but they recommended that I "make sure the kit contains OE style Borg Warner paper friction plates". I'm searching around and I can't find anywhere that even lists that as an option. Anyone have a recommendation?
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
12-18-2018, 01:54 AM | #2 |
Re: TH400 rebuild kit question
I don't think there would be an issue if you ordered a quality rebuild kit...maybe even from transgo themselves
12-18-2018, 12:12 PM | #3 |
transtar is a dam good bang for the buck rebuild kit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-24-2018, 12:27 AM | #4 |
If you've never done a 400 before be advised they not like a T350 in one way.
There is a bolt in the case that holds the center support in, and you must remove the valve body to get after this bolt. Other than that they are pretty much like a T350. Good Luck! |
12-24-2018, 01:24 AM | #5 |
Thanks for the advice guys. My friend will be helping me with the rebuild (I've never even seen the inside of a transmission). My biggest question was about the paper style friction plates, since I'm not sure if that is important or why it was recommended. I'm planning to go with a TCI kit.
12-25-2018, 11:29 PM | #6 |
Anybody's good quality kit will have the friction material you need. Just check your clearance after you stack them in the drums & after you get them set remove the frictions & soak them in ATF for an hr or so & re-install them & you'll be fine.
12-26-2018, 05:49 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Clinebarger turned me on to this guy for the kits, https://www.ebay.com/usr/worldwidepa...72.m2749.l2754 He's thorough and his pricing is hard to beat. Most all your stage 1&2 kits will have the paper frictions...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
