07-13-2020, 06:23 PM | #1 |
Spot Putty Help
I've treated the rust spots on the front of my hood with a rust treatment. I've tried filling the low spots with spot putty (3M Bondo 801) and my first attempt was futile - it hardened too fast (3M's instructions are not very clear on ratio). I tried again with half as much hardener - the Bondo was barely pink. It still didn't seem to stick in the low spots. I tried it without hardener and although it seemed to dry it made a mess when I tried to sand it. There are a couple of possible reasons I've thought of - it's almost 100 degrees, and I'm working outside, and the tube I have is a couple of years old. I used it on my firewall when I first bought it, and it seemed to work fine.
So what spot putty should I be using? What's the correct mix ratio? Should I spray the primer first, and then putty? Any help is appreciated. Thanks! The driver's side of the hood was covered with a skim coat of spot putty before I sanded it:
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-14-2020, 06:22 AM | #2 |
Re: Spot Putty Help
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
07-14-2020, 06:23 AM | #3 |
Re: Spot Putty Help
You will also have better luck cross sanding with a longboard or durablock
07-14-2020, 09:13 AM | #4 |
Re: Spot Putty Help
I would put epoxy primer on it first and then do the filler.
Works better for me that way. But I'm no body man. Kim |
07-14-2020, 09:37 AM | #5 | |||
Re: Spot Putty Help
Thank you all!
07-14-2020, 01:23 PM | #6 |
Re: Spot Putty Help
I second the epoxy primer, 2 coats and apply filler based on the epoxy tech sheets recommended time. Didn’t want to suggest too much and help spend your money!!!
07-14-2020, 02:31 PM | #7 |
Post Whore
Re: Spot Putty Help
all of this is bad...( it's almost 100 degrees, and I'm working outside, and the tube I have is a couple of years old)
.... epoxy will help fill most of the pitting...i used evercoat metalglaze...very good stuff...not sure what you ordered..3M ?.....durablocks are good but 1/4" strips of lexan with the corners slightly rounded is better...
07-14-2020, 02:52 PM | #8 |
Re: Spot Putty Help
My concern is in your original post you said you were using some kind of rust converter this can cause you a problem It doesn’t always play well with epoxy primer‘s you should never put any type of body filler or glaze over bear metal I would suggest you sand it all down to bare metal and get rid of as much or all of the rust converter as possible SPRI is a good affordable epoxy primer
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
