Old 11-04-2019, 11:02 AM   #1
palallin
Air Bag Lit
So, as of this AM, the Air Bag light stays on in my wife's 2001 Tahoe.
The manual just tells me (to paraphrase): go to the dealer and spend money.
If there anyway to find out what the problem is with following the manual? am I looking at a potential random deployment or just a chance it won't deploy in a collision?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 11-04-2019, 12:14 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Air Bag Lit
It will store a code. Random deployment is very rare and almost impossible. Front impact sensors and clocksprings are common. You need to get someone that can pull codes.
95 S_Trucker is offline   Reply With Quote
Old 11-04-2019, 03:41 PM   #3
Ziegelsteinfaust
Re: Air Bag Lit
Many auto parts stores lend code readers to determine what is wrong, and then you can decide if you can fix it.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-04-2019, 03:58 PM   #4
95 S_Trucker
Re: Air Bag Lit
Most code readers will just read PCM codes. You'll need to find one that can communicate with the airbag system.
Old 11-05-2019, 10:26 AM   #5
palallin
Re: Air Bag Lit
OK, thanks, guys.
The light has since gone out, so I will monitor it closely.
Old 11-05-2019, 03:14 PM   #6
biketopia
Re: Air Bag Lit
You can still get the code from memory, as long as the battery hasn't gone dead or been disconnected. If you have access to a buddy who can maybe pull SRS codes it would sweet to know what is going on. Like states front impact sensors and clock springs are common, more often I've seen the impact sensors.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-14-2019, 09:35 PM   #7
hugger6933
Re: Air Bag Lit
Check your fuses, also look at the rear view mirror it it not lit? then you have a fuse blown and that would make the SRS light stay on also plugs can loosen although rare I have had it happen.
hugger6933 is offline   Reply With Quote
