Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-25-2017, 03:33 PM   #1
truckster
truckster's Avatar
First Attempt at Sheet Metal
I started working on putting my Blazer back together, and I decided to repair the fenders that were on it when I bought it. The right side only has a couple of dings, but the left had these holes that looked like a bumper had worn through it at some point.
I decided to try welding them up using 18 gauge sheet metal for the smaller hole and a piece I cut out of a damaged fender for the larger hole. Here's how it ended up. My plan from here is to use a little body putty to finish it off, but if any of the body and paint guys out there think I should do something different I'd like to know.
Thanks.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 11-27-2017, 01:26 AM   #2
MP&C
MP&C's Avatar
Re: First Attempt at Sheet Metal
Narrow slivers are the hardest to repair as it concentrates the heat in such a confined area, adding to distortion and shrinking issues. For any such future work I would suggest a wider, parallel gap with a radius at the end. The wider the better, for separating the heat affected zones. Position seams where better access for planishing the welds exists..
For that damage, given adequate access from the back, I would have considered making one large patch to span the two slices, cutting out the center, using a radius at the end. This would give you two horizontal weld passes vs. the four that you used. Less welds, less distortion.
Robert
MP&C is offline   Reply With Quote
Old 11-27-2017, 07:04 PM   #3
MARTINSR
MARTINSR's Avatar
That stuff looks pretty good but can you show what in the hell you are working on. I can't for the life of me figure out what I am looking at.
The only real bad thing I see is you changed the "body line" on that recessed area. It will now have to be sculpted out of bondo.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-27-2017, 08:41 PM   #4
BIGglaSS
BIGglaSS's Avatar
If you can see daylight through it, it's not ready for filler.
BIGglaSS is offline   Reply With Quote
Old 11-27-2017, 09:38 PM   #5
72HuggerK20
MARTINSR that is the front fender of a 67-72 pickup. The part he is working on is half hidden by the front bumper.
72HuggerK20 is offline   Reply With Quote
Old 11-27-2017, 10:08 PM   #6
MARTINSR
MARTINSR's Avatar
Ahhh, thanks, ok, I can see that now. But it's not hidden, the bumper rides above that. The line is going to have to be made out of bondo, not a good way to go.
Brian
1948 Chevy pickup
Old 11-27-2017, 10:17 PM   #7
truckster
truckster's Avatar
Well, I ran out of warm weather so it will have to do for now. I sealed it with primer and once I get the engine in and my new wiring harness done I'll hang the front clip and drive it for the winter.
I'm a decent welder, but sheet metal is a whole different beast. Fortunately, I have some spare panels to practice on.
Old 11-27-2017, 10:19 PM   #8
MARTINSR
MARTINSR's Avatar
OH HELL YEAH it's a whole different beast! I have an old friend who is a professional welder. He had a pocket knife with a tiny perfect bead laid on the back edge of the blade. But put him on a car.....OMG I couldn't even fix what he screwed up, OMG! It was a 39 Chevy sedan, I remember it well trying to correct what he did, YEOW.
Brian
1948 Chevy pickup
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
