Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-10-2017, 11:48 PM   #1
mongocanfly
which orbital sander
Im gonna have to get a new orbital sander...while looking I see a regular and a contour.......if I was only buying one which one would be best...keeping in mind I'm no body man...just home projects...it will be a 3/32" thanks
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 12-11-2017, 01:20 AM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: which da sander
I think a 6 inch orbital palm grip sander would be the best all round one. It is lighter and only need one hand to use. Something like this from Summit, but there are other brands that are good too.
Hutchins HTN-700
PDW HOTRODS is offline   Reply With Quote
Old 12-11-2017, 07:07 AM   #3
mongocanfly
Re: which orbital sander
yes...I should have stated it but a palm sander is what I'm looking at...like this one.....http://www.eastwood.com/contour-pro-...-32-orbit.html
Mongo...aka Greg
Old 12-11-2017, 08:12 AM   #4
mongocanfly
vs one similar to this......http://www.eastwood.com/6-in-dual-ac...lm-sander.html
Mongo...aka Greg
Old 12-11-2017, 02:28 PM   #5
MARTINSR
MARTINSR's Avatar
Re: which da sander
I highly recommend something to the very top end of your affordably level.
There can be a big difference between a cheap one and an expensive one, one that would save you hours upon hours of work, and interestingly enough one that can save you a ton of sand paper too! A poor performing tool can wear you out and wear out sand paper with it doing nothing for you, believe me!
So, step it up to something like this.
http://www.eastwood.com/pf-3-32-in-offset-palm-sander-6-inhk-pad.html?mrkgcl=764&mrkgadid={_mrkgadid}&rkg_id=h-6caebd465572a93ebf2c414b8d004565_t-1513016564&product_id={product_id}&adpos={adposition}&creative={creative}&device={device}&matchtype= {matchtype}&network={network}&SRCCODE=PLA00020&gclid=EAIaIQobChMIzqbo9MmC2AIVFdNkCh0fkwl3EAQYAiABEgL GgPD_BwE
Or what I have..
https://ballewsaw.com/dynabrade-ezq6...CABEgIVnPD_BwE
Edit: I can't search for the right one right now, but I think this one I Just posted is more for finish sanding with a finer smaller rotation. Get the more universal one if you are going to be using it for more aggressive sanding like striping or bondo work.
I HIGHLY recommend to not buy the cheapies!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 12-11-2017, 02:34 PM   #6
MARTINSR
MARTINSR's Avatar
Re: which da sander
Here are some options! https://www.grainger.com/category/pn...ts_optout=true
Honestly, this thing is basically a 6" "block" it is amazing how flat you can get bondo work with one of these only then needing to fine tune with the regular block.
Brian
1948 Chevy pickup
Old 12-11-2017, 09:42 PM   #7
mongocanfly
Re: which da sander
I'm not really worried so much about price as quality....right now I'm at the epoxy primer stage and doing filler work at the moment...so thats what I'm mainly needing so I'm guessing I need the 3/16" orbit instead of 3/32" .?....my old one won't even run anymore and I have no idea what orbit it is...but I know its a very cheap sander
Mongo...aka Greg
Old 12-11-2017, 10:28 PM   #8
MARTINSR
MARTINSR's Avatar
Re: which da sander
Yes you want the 3/16
Brian
1948 Chevy pickup
Old 12-11-2017, 10:36 PM   #9
mongocanfly
Re: which da sander
thanks...I may run to grainger tomorrow and see what they'll do on a 6"...3/16"...I get a pretty descent discount there thru my work..this maybe.#13f633..https://www.grainger.com/product/DYN...eadcrumbCatId=
Mongo...aka Greg
Old 12-11-2017, 10:41 PM   #10
mongocanfly
Re: which da sander
or this..#13f637....https://www.grainger.com/product/DYN...eadcrumbCatId=
Mongo...aka Greg
Old 12-11-2017, 10:51 PM   #11
MARTINSR
MARTINSR's Avatar
Re: which da sander
I'll try later but that link is giving me "your connection is not private" and I can't go there for some reason.
Brian
1948 Chevy pickup
Old 12-12-2017, 05:07 PM   #12
kingNothing
kingNothing's Avatar
Re: which da sander
https://www.summitracing.com/parts/dyb-21035/overview/ I have this d.a/ its about 7 years old and still works great
Yeah' well sometimes nothin' can be a real cool hand
Lucas Jackson
kingNothing is offline   Reply With Quote
Old 12-12-2017, 05:08 PM   #13
72HuggerK20
Re: which da sander
I prefer the 3/32 because I only use a DA for finer work. For bodywork or primer, I'd rather do it by hand or with an inline sander on the real coarse stuff. Hutchins makes the best DA out there, hands down. I really like the MAC tools DA though.
72HuggerK20 is offline   Reply With Quote
Old 12-12-2017, 05:10 PM   #14
72HuggerK20
Re: which da sander
Also, hook and loop backing pads/paper are the only way to go IMO
Old 12-13-2017, 02:51 PM   #15
MARTINSR
MARTINSR's Avatar
Re: which da sander
I have to tell you, I use the orbital 6" and 8" "Hog" National Detroit 900 right up to just fine tuning with a block. I have actually did a lot of repairs right to finish with the 6" and it came out awesome.
Think of it a "block" as it truly is basically the same thing! It's not spinning remember, so if you had a 6" rubber block that gyrated around like that sander you could still "block" filler right?
It's amazing what you can do with those tools! I have a Hutchins 3804 orbital long board like this too. It's basically as I describe with your hand block gyrating, it's amazing.
Brian
1948 Chevy pickup
Old 12-13-2017, 03:01 PM   #16
72HuggerK20
Re: which da sander
I think you're getting a little ahead of yourself Brian. I'm not sure I'd tell a guy with very little experience doing bodywork to use a DA for that purpose right off the bat. It takes a lot of practice to be able to control a DA and do good, flat work with it. Yes, a block takes more time, but is a lot easier to control as a beginner. That's why I'd recommend, at least in this context, a DA only for things like refining sanding scratches in primer after blocking or sanding clear. I think a 3/32 DA is much better for this, and is suitable for anything else other than heavy stripping or bodywork jobs.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
