03-12-2020, 09:05 PM | #151 |
Re: 85 C10 LT/6L80 Frame off build
Looks awesome Luke. I’m looking forward to seeing it around town and hopefully at LS Fest
03-14-2020, 10:49 AM | #152 |
Just awesome man! What are the specs on the exhaust pipes? Love the subtle factory style...
1984 Chevrolet C10 |
03-17-2020, 09:20 AM | #153 | |
several options available https://www.holley.com/products/engi...ap_components/ |
03-17-2020, 09:24 AM | #154 | |||
Thanks guys, hang around I'll post up more pics |
04-06-2020, 11:25 PM | #155 |
BMW & ASE Master Certified
The alternator wire isnr getting warm.is it? Hard to tell how beefy it is but I installed some stock Camaro e fans on a build and that wire happend to be to small. Another note, is that a new 4 core rad support bracket? If so where did you source it from?
Fantastic build!
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-07-2020, 08:12 AM | #156 | |
07-06-2020, 02:31 PM | #157 |
chevy truck fan
luke,
Thanks again for sharing this build. I re-read the thread again & did not see what you did for your trans linkage? would you be willing to share how you connected the trans to the steering column (in relation to shift linkage)? Also I was wondering if you would share what wires on your firewall block (truck) you are using on the engine portion to the LS? I would like to know what wires you used from the truck part of the harness? thank you again & I am following along on the blazer build too!! |
04-06-2021, 03:37 PM | #158 |
Not sure if this was posted, but CONGRATULATIONS Luke!
https://www.streettrucksmag.com/old-...-84-chevy-c10/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-06-2021, 04:53 PM | #159 |
Very nice article.... Congrats!
04-07-2021, 07:40 AM | #160 |
Good coverage of the truck and a well-written story. Congratulations Luke!
04-07-2021, 07:59 AM | #161 |
Luke, are the right angle hard lines part of the kit? I ask because the V/A installations I've done run the heater and refrigerant hoses through the firewall into the interior. An accident waiting to happen, IMO, especially with heater hoses.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-07-2021, 10:40 AM | #162 |
chevy truck fan
Mike,
The V.A. "sure fit" systems includes everything needed to replace a factory A.C. system, so yes the right angle hard lines are part of the kit. I have the same version in my build & the 4 lines run through the firewall with a supplied cover plate. when I did my '72 I used a "universal" kit setup & I did what you have done, I felt the same way, although I did not connect the heater hoses (I'm in the desert and it was a show truck). I would feel comfortable to run them how V.A. instructs to do it. I feel V.A. is a quality system with many satisfied customers. I am on my second system personally & very happy. hope this helps. |
04-07-2021, 10:55 AM | #163 |
Thanks, I just noticed that on the instruction sheet for the Gen IV unit. Lots of improvements over my 69 C10's 1998 system.
07-12-2021, 11:45 AM | #164 |
chevy truck fan
luke, just noticed a thread about the holley truck bed mat..... and the truck "model" looks really familiar.. do you know anything about the truck model...
either way still a VERY NICE build... |
08-14-2022, 11:57 AM | #165 |
Been awhile so I thought I’d share a few updates. Swapped out the brakes to a new set up, changed to blue interior, manual T56 swap. More pic to come later today.
08-14-2022, 02:20 PM | #166 |
He works for/at Holley.
08-14-2022, 05:11 PM | #167 |
Looks better than new. No detail overlooked.
08-14-2022, 08:22 PM | #168 |
08-14-2022, 10:02 PM | #169 |
Wash job today, getting ready for a local car show next weekend
08-14-2022, 10:13 PM | #170 |
Then off to Home Depot for lumber and gravel!
08-21-2022, 11:39 AM | #171 | |
Thanks Frank
Born and proudly residing in a Red State ! |
10-11-2022, 10:24 AM | #172 | |
I'm doing an L86/8L90 swap in a 93 and an 84. In the 93 I used Dirty Dingo adjustable motor and transmission mounts and they worked out great. There's not issue with the tranny tunnel and the factory headers as well as the factory gear selector mechanism bolted right in. I also used the holley LT mid-mount setup and it looks great, pic included. Any suggestions on what brackets to use on the 84? Will any of them work with 8L90? Am I going to have to find a high hump transmission cover? Sorry for all of the questions, but appreciate any advice that you can pass on. Take care, Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-11-2022 at 10:30 AM. |
10-31-2022, 04:07 PM | #173 |
