01-13-2012, 05:40 PM | #51 |
Re: Let See Seats On Your 55-59 Truck
these are out of an 07 ford fusion, did not like them sticking up in the back window.
i cut the backs down 6'' and removed the headrest, a friend recovered them in ultra suede nice truck/interior Entourageguy
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-13-2012, 06:25 PM | #52 |
I have read ( on a few forums) questions asked about " what to use when rebuilding a seat" This is just to document what I did to the frame/spings and build up with a cover pre cut and sewn ready to install.
I stripped mine down to the frame/springs, repaired any springs or bars that were damaged. I pulled/stretched all of the springs that had seen abuse over 60 years making sure that all of them looked even and square within thier individual area. I painted both halves of the seat-frame-springs then covered the bottom and back assemblies with burlap that I hog ringed to the spring retainer bars so it wouldnt slide around. I layed cotton batting over the burlap on the back portion and fit the cover. Anything thicker than the cotton will push you forward ( great for shorter people) I Stretched the cover around and hog ringed it down-forget about those factory clips, they tear the vinyl and are a p.i.a. rings work great. After the burlap secured to the lower section, I cut out a 2 inch slab of medium density foam and lightly glued it to the burlap with spray adhesive. Tossed the cover on, pulled the edges, hog ringed it on. I started in the middle of the seat and worked my way to the outsides both front and back of each seat halve together, pulled and ringed the sides last. Installed the base, slid it forward and installed the back. Slid it back and went for a ride....no bouncing, looks great ( some areas will relax a bit in the sun etc). |
11-13-2012, 07:13 PM | #53 |
Looks awesome. Nice work
Posted via Mobile Device |
11-13-2012, 07:39 PM | #54 | |
11-13-2012, 08:00 PM | #55 |
Here's mine 07 Yukon third row with shoulder belts built into the seat.
11-14-2012, 12:14 AM | #56 | |
If it's as simple as you wrote I'll definitely being trying it if the price is reasonable. One quick question: the "cotton batting" you speak of; where'd you get it and how thick is it? P.S. Is that a piece of matching vinyl, or paint on the door panel? |
11-14-2012, 02:10 AM | #57 |
http://www.ricksupholstery.com/CompletedTrucks.html
I also had them sew up a matching headliner and was $250 shipped for all 3 pieces. The door insert is hammerite spray bomb in a dark metallic gray not vinyl. The cotton batting is a really light and fluffy material that came on a roll from a local fabric/uphoulstery shop supplier. Its only about 1/2 mabey 3/4 but you can grab and pull it off the roll and make snowballs with it by wadding it up. It really is simple but I had the same reservations too. Pm me and I can walk you through it or call you and explain it better than I type Posted via Mobile Device |
11-14-2012, 12:31 PM | #58 |
Wow. Thanks for the link. At the price you quote in definitely gonna try them. I expected little in the way of choice but I'm impressed with what they offer.
11-14-2012, 12:54 PM | #59 |
[QUOTE=NEWFISHER;5700824]I have read ( on a few forums) questions asked about " what to use when rebuilding a seat" This is just to document what I did to the frame/spings and build up with a cover pre cut and sewn ready to install.
I stripped mine down to the frame/springs, repaired any springs or bars that were damaged. I pulled/stretched all of the springs that had seen abuse over 60 years making sure that all of them looked even and square within thier individual area. I painted both halves of the seat-frame-springs then covered the bottom and back assemblies with burlap that I hog ringed to the spring retainer bars so it wouldnt slide around. I layed cotton batting over the burlap on the back portion and fit the cover. Anything thicker than the cotton will push you forward ( great for shorter people) I Stretched the cover around and hog ringed it down-forget about those factory clips, they tear the vinyl and are a p.i.a. rings work great. After the burlap secured to the lower section, I cut out a 2 inch slab of medium density foam and lightly glued it to the burlap with spray adhesive. Tossed the cover on, pulled the edges, hog ringed it on. I started in the middle of the seat and worked my way to the outsides both front and back of each seat halve together, pulled and ringed the sides last. Installed the base, slid it forward and installed the back. Slid it back and went for a ride....no bouncing, looks great ( some areas will relax a bit in the sun etc). ] may I add that you can make a plywood frame about 2 inches wide all the way around that screws into the bottom of the seat frame. this elimanates the hog rings witch are hard to get an even pull with. With the wood strip you can staple the cover and get a nice even pull. |
11-14-2012, 01:28 PM | #60 |
[/QUOTE]
may I add that you can make a plywood frame about 2 inches wide all the way around that screws into the bottom of the seat frame. this elimanates the hog rings witch are hard to get an even pull with. With the wood strip you can staple the cover and get a nice even pull.[/QUOTE] If your stapler is powerfull enough, it will shoot them directly into the lower seat pan also |
11-14-2012, 02:22 PM | #61 |
The staples won't just pull through and tear the vinyl/fabric? Interesting idea. I'm thinking the plywood would have to be at least 1/2-5-8" thick? Fairly close spacing on the bolts holding it to the seat frame(?)
11-14-2012, 03:00 PM | #62 | |
.. .. Pic stolen from another site, but shows the plywood technique Last edited by NEWFISHER; 11-14-2012 at 03:07 PM. |
11-14-2012, 07:05 PM | #63 |
no hog rings will tear before staples will. I use staples on motorcycle and smowmoble seats. that is how most origanally were done. If you don't trust a stress point adda little 3w weather strip adhesive{good contactact cement}
11-14-2012, 07:06 PM | #64 | |
11-14-2012, 07:17 PM | #65 | |
11-14-2012, 07:21 PM | #66 |
And the matching headliner installed at lunch, just need to trim the edge tonight.
11-14-2012, 07:39 PM | #67 |
looks great! sure makes a big difference.
01-24-2013, 07:40 PM | #68 |
heres a late 80's seat in my 57
1957 3100 1950 5 window |
01-24-2013, 08:30 PM | #69 |
^^^comfy
01-24-2013, 09:01 PM | #70 |
heres a photo of my factory seat and $20 worth of serape blankets.
A Sane Man in an Insane World |
01-24-2013, 10:26 PM | #71 | |
So the plywood is one piece? NOT four separate pieces, right?
Newfisher: I probably asked you this already but you just sprayed your door panel trim with metallic silver paint, right? That's what I did on my two tone door panels but I was just wondering. Pic of my door panel below. Quote:
01-24-2013, 10:29 PM | #72 | |
01-24-2013, 11:16 PM | #73 |
Choady....I'm a fan of the sticker
Dan.....4 seperate pieces of wood, easier to deal with. I've seen them screwd down and also through bolted then staple the seat material to the board. Hog ringing works just fine though. Throw away the c clips that the factory held the material with as they do more damage cutting the vinyl when installing them. Yes, I'm a copy cat. I stole your metallic chrome bumper spray bomb technique. Pm me your paypal addy and I will tithe you the royalty Posted via Mobile Device |
01-24-2013, 11:38 PM | #74 |
01-25-2013, 12:26 AM | #75 |
