01-18-2013, 10:01 PM | #1 |
36" or 37" tires.
Anybody make streetable tires in these sizes? My truck is lifted about 7" all spring and currently has 35s that look a little on the small side. I don't wheel this thing do to not wanting to trash it and it not really fitting on what few trails there are around here. Ive been looking for a 36 m/t or even a/t but havent seen much other than a swamper and I don't really want to spend 1200 bucks on tires that are going to be bald in a year of driving around town. Anybody have any suggestions? I've got 15x10 wheels.
01-19-2013, 02:23 AM | #2 |
Re: 36" or 37" tires.
BFG muds. The new KM2 comes in a 36x13.5
Although if you were a boss, you'd roll the 36x15.5 Mickey Thompson MTZs. I have wet dreams about those tires (I live 5 minutes from the dunes, where wider tires reign). Posted via Mobile Device |
01-19-2013, 02:39 AM | #3 |
Why not 38s or bigger ?
01-19-2013, 06:14 PM | #4 |
Find some military take-off 37" tires. They are radial, moderately good offroad, and I hear they wear like iron on the road.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
01-19-2013, 06:20 PM | #5 |
+1 on the military tires if you want CHEAP.
My favorite is the toyo m/t. I ran mine for 20,000 miles and they still had half life it looked like. |
01-19-2013, 08:37 PM | #6 |
+1 on the military surplus. I'd like to run those if I hadn't found a set of MT/KO's new for 600. I like the way the military tires look and the tread design and hear that they wear well too.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
01-20-2013, 03:36 AM | #7 |
I think Goodyear used to make a 37/12.50r15 mtr that would let you keep your current wheels. I saw a set on pirate earlier this month for 650 but think they went fast.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
01-20-2013, 07:35 PM | #8 |
The military 37's aren't that big though, they measure a little over 35" if I remember right.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
01-21-2013, 05:44 PM | #9 |
I'd be all over the millitary tires if it weren't for the 16.5 wheels size. I don't think I'd clear a 38 and it took too long to find good GM sheet metal to be hacking it up for tires. I've only got half to running gear with 3.73 gears also and just spent 1200 bucks building another rear end last year after getting rear ended so I'd kinda like to keep that for a few years at least.
01-21-2013, 09:30 PM | #10 |
My favorite tire is still the TOYO M/T. Where I am, you can get a full set with wheels for $1K with little miles on them.
01-27-2013, 07:24 PM | #11 |
i would skip mt's and get at's i think bfg makes 37s for both
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
01-28-2013, 03:46 AM | #12 |
not my fav. tire, but still an excellent tire. have a set of 38x15x16 M/T's, wear like steel, big load capacity, rock solid-no shimmy or shake, decent price, good in all except heavy mud. whacked my front one on the rocks hard enough to dent the bead 2 yrs ago, still holds air. i would'nt recommend swamps for daily driving. my 38.5 sx's wear good, but the crew rocks & rolls down the road on them
01-31-2013, 01:47 PM | #13 |
i run the toyo m/t's on my truck 37x14.50x15. very streetable and they do wear like steel.
1986 Chevy Wrangler 4x4 305/700r4 6" lift 37x14.50x15 |
02-04-2013, 07:52 PM | #14 |
How do those toyo m/ts do in the snow ? I think im about to pull the trigger on some 37x14.50x15s
02-04-2013, 08:28 PM | #15 |
i find them great in snow, lots of siping on them. heavy mud is about the only drawback unless you got lots of power to clean them out
02-04-2013, 08:36 PM | #16 |
+1 Good in snow and daily driving on the street. If you wanted tires for some heavy mud, get swampers or something
02-04-2013, 08:41 PM | #17 |
Not to mention the Toyo's are just a good lookin tire without being over the top
02-05-2013, 06:52 PM | #18 |
Toyo m/t 37x14.50x15s on the way, hope they fit..
Thread Tools | |
Display Modes | |
