07-17-2019, 03:39 PM | #1 |
Electric fan question
I’m going with a 1995 Ford Taurus 3.8L fan and Volvo 850 relay. Anyone have this setup? I’m worried that the relay is gonna be to small for the amp draw.
I have a diagram I found on another forum, but it doesn’t include AC trinary or any diodes. Does anyone have a diagram they can share? Posted via Mobile Device |
07-17-2019, 04:18 PM | #2 |
Instead of a dual temp switch, the ecu will turn low on at 195 and high on at 215.
Posted via Mobile Device Last edited by prodjay10; 07-17-2019 at 04:27 PM. |
07-18-2019, 12:27 PM | #3 |
Re: Electric fan question
There’s a lot of info online stating the fan for the Volvo is the same fan as the Taurus with the difference being the shroud. Bet the relay is going to work great.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
07-18-2019, 09:15 PM | #4 |
Have you seen how much draw the fan consumes when it comes on? Iirc it was real high, kinda made me go a different way.
Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-18-2019, 09:17 PM | #5 |
I used fan relays from PSI....I looked but cant find a amp rating...but I've never had a issue with them
07-19-2019, 09:20 PM | #6 | |
I did test the fan today with a car battery and man does it pull air! I was surprised. Posted via Mobile Device |
07-19-2019, 09:26 PM | #7 |
Thanks for the replies. I’ll let y’all know how it turns out.
07-19-2019, 09:28 PM | #8 |
I do have another question. Is it possible to have the AC request to turn on fan but the fan be turned off at low temperatures or when going over 35mph? Or is this a bad idea?
07-20-2019, 07:30 AM | #9 |
Yes, that is where the trinary switch come into play. Have it ground the high speed relay and it will kick the fan on when the head pressure gets high enough, then when you're on the road above 40mph or so, the pressure will be low because of the airflow and the fan will be off.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-20-2019, 05:20 PM | #10 |
07-22-2019, 12:51 PM | #11 |
That relay should work, I have the Windstar fans which everyone said drew some crazy high amperage but I have been running a 40 amp relay on them for a couple months with no issue. I have both set to turn on at the same time so it must not be all that high.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
07-23-2019, 05:16 PM | #12 | |
thanks! |
07-23-2019, 05:40 PM | #13 | |
07-24-2019, 01:48 AM | #14 | |
Power is directed by grounding one of the middle wires. |
07-24-2019, 04:08 AM | #15 |
You can wire like this without a Volvo 2 speed fan relay.
