01-03-2018, 05:17 PM | #1 |
84 quad lights, pass low beam works only with high beam
Hello,
I've tried to search but have found no answers, I swear I read it last year while looking at headlight threads. The passenger side low beam light does not go on. It will only come on with the high beams on. I've done nothing recently to change anything electrical, I also checked to be sure the ground was good and it was. Any help would be great, I know it's not the bulb. Thanks in advance! Rob |
01-05-2018, 07:08 PM | #2 |
Re: 84 quad lights, pass low beam works only with high beam
I'll bump this one back up. I recently had the same issue after installing an aftermarket headlight harness. I never did figure out the problem. Maybe someone with an idea on this issue will lead to a solution on mine too.
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
01-05-2018, 07:36 PM | #3 |
Check your connection at the headlights. Could just be a loose connection or wire
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-05-2018, 07:40 PM | #4 |
It could also be that the low beam bulb is burned out. Might just need new headlights. But check the connections first.
01-05-2018, 07:47 PM | #5 | |
I know the bulb works because it comes on when I switch to high beams. I inspected the three prong male side of the bulb and can only see that it might be an internal issue. All wires are good, connections are good. Just an odd scenario, and seeing how xs-style also has the same issue at least makes me feel like I'm not crazy! For now I just unplugged the high beams and run the lights on high beams so the low beams can function. Thanks for the help! |
01-05-2018, 08:02 PM | #6 |
I would try a new switch, or borrow one that is working, the one that switches from high to low, they cant be that expensive,
01-05-2018, 08:05 PM | #7 | |
01-05-2018, 08:12 PM | #8 |
For another weird twist, my lights will work as they should without the harness. They only have the symptoms you have with the relay harness installed.
01-05-2018, 08:17 PM | #9 |
The low beam bulbs have two filaments? This would be surprising to hear since there's four lights and I thought there were just single filament bulbs each.
01-05-2018, 08:18 PM | #10 |
You guys aren't using LED bulbs by any chance? I know I tried changing all my bulbs over to LED's. Talk about weird issues, I had all kinds of issues. Switched them back and everything was fine.
01-05-2018, 08:20 PM | #11 |
Duh, that's right, you have quad headlights. That would only be for a single headlight, they have two filaments.
01-05-2018, 08:35 PM | #12 |
I dunno about the op, but I'm just using standard Sylvania bulbs in my case
01-05-2018, 08:36 PM | #13 |
In this thread (great thread by the way) look at X8430 and find the quad headlight diagram. There are three pins and two elements in the lowbeam (even in a quad light system). Your one element is burned out, the other is still good.
http://67-72chevytrucks.com/vboard/s...d.php?t=545416 |
01-05-2018, 08:45 PM | #14 | |
01-05-2018, 09:27 PM | #15 | |||
I ordered another bulb and will post once it's in and hopefully working again. Thank you everyone for your help! Rob |
