Old 01-08-2018, 09:17 AM   #26
Beatrice
Beatrice's Avatar
Re: Saving the 63' from the grave
did get the new skins on last week and spent about 6 hours sat aligning the door and front end. fairly happy with the skins we all know the factory gap work isn't the best on these anyway so i have some hours ahead of me cutting and getting my gaps where i want them. got my f body pan coming this week to so i can mock the engine up to check for clearances.
Beatrice is offline   Reply With Quote
Old 01-23-2018, 02:25 PM   #27
Beatrice
Beatrice's Avatar
got all the bed parts in so got started on that. once i get it all mocked up i can get back into all the gap/fitment and final bodywork. also got the mock up 5.3 put in to check clearances on everything. had to do some trimming inside cab for the top of trans but very minimal.
Old 01-23-2018, 02:35 PM   #28
jhrusk
Nice. U are making quick work of it.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 01-23-2018, 05:57 PM   #29
aggie91
I'm just glad to be here!
aggie91's Avatar
Very Nice work so far.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-23-2018, 08:39 PM   #30
66C10LB
Looks like it is lining up nicely. Looking forward to seeing more of your progress.
66C10LB is offline   Reply With Quote
Old 01-24-2018, 12:32 PM   #31
343CA
Nice quality work and yes most replacement panels are lacking proper fitment.
343CA is offline   Reply With Quote
Old 01-24-2018, 12:42 PM   #32
Beatrice
Beatrice's Avatar
got most of my parts from nsaneparts and very happy with them. the door skins I did not and those were the worst panels on it so far but I expected the gaps to be off there.
Old 06-25-2018, 11:53 AM   #33
Beatrice
Beatrice's Avatar
been slacking on updates on here. so here are some recent progress shots. most bodywork is complete just some touch up and probably one last block to triple check everything. got a lot of smaller parts rolling in while i'm getting the front tubs and core support area built
Old 06-25-2018, 01:02 PM   #34
jchav62
1962 C-10
jchav62's Avatar
Friggin' AWESOME work!! I'm lovin' it....
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-25-2018, 01:27 PM   #35
Beatrice
Beatrice's Avatar
few more pics. this is where the truck is at today. bunch of customer work to push out so will be on the back burner for a couple weeks.
Old 06-26-2018, 09:02 AM   #36
aggie91
aggie91's Avatar
Great work.
I'd like to see more on the hood latch set up you installed. Also, looks like you are going to turbo the engine since it looks like an intercooler mounted up in that one picture.
Those door panels are insane, did you make them or where did you get them?
Karl
The LST Challenge:
Old 06-26-2018, 09:11 AM   #37
Beatrice
Beatrice's Avatar
I will try to get some more latch pictures once the hood goes back on.
The truck has a built 5.3/4l80 with a Procharger D1SC going on it.
Munnsey speed and design makes the carbon door panels. they make a lot of composite parts for the 60 and up chevys and quality is top notch.
Thanks for all the kind words guys. Can't wait to get it out and about. hoping to travel a lot with it to some of the bigger shows out west next year too.
Old 06-26-2018, 09:17 AM   #38
jchav62
1962 C-10
jchav62's Avatar
Looks f'n killer... The door panels look SICK! I can't wait to see her done.
Joseph Chavez
Old 06-26-2018, 10:01 AM   #39
rwade
rwade's Avatar
Can I see some more pictures of where the front bed panel meets the wood and how the hinges work when it opens? How does the wood not hit the front panel when it opens? Your truck is looking real nice!
Thanks, Wade
rwade is offline   Reply With Quote
Old 06-26-2018, 10:08 AM   #40
Beatrice
Beatrice's Avatar
i'm using a "c" or "u" shaped hinge that as the bed hinges up it goes toward the rear of truck a bit. it's not much the wood is still close to hitting. I also put a 45 degree cut on the front of the wood pieces so that when it goes up there is more clearance on the bottom side of the wood so it doesn't come in contact.
i'll see if I have any more detailed pics on my phone and post up when I get a chance.
Old 06-26-2018, 10:13 AM   #41
lolife99
67-72 parts collector,…
lolife99's Avatar
Super nice work.
Following this build,...
Keith
Convert to disc brakes.
Old 06-26-2018, 10:24 AM   #42
Beatrice
Beatrice's Avatar
rwade
here is all i have on my phone. i welded a lip all the way around to tuck the wood under. wanted it smooth with the inside panels which is the reason i did it this way. the wood barely tucks under it on the hinged center section. as you lift that section it comes back-up-and the farther you lift up the more it goes back forward. hope that makes since. it essentially make the wood sit underneath that lip to directly on top and you can see why i had to 45 the bottom of wood. this pic is with the section up farther than what i have it now with the shocks on it so the wood doesn't even sit that close to the top now.
Old 06-26-2018, 08:32 PM   #43
rwade
rwade's Avatar
Man that’s an awesome idea! If you have time I’d love to see an up close of the hinges. I’m guessing you’ll be using some sort of flat bar? Or traditional bed strips?
Wade
Old 05-31-2019, 02:14 PM   #44
Beatrice
Beatrice's Avatar
wow guess it's been a while since i've updated. side work has been crazy busy so the c10 has been sitting idle for a while but heres some progress. got pretty much all the parts just need to finish up some odds and ends bodywork and should be ready to get into some other projects. engine is being built ended up going with a 5.3 and boring it out to a 5.7 with Callie rods and custom wiseco pistons. will be a pump gas cruiser with the Procharger D1SC around 10-12psi.
also got all of the accuair cvt with elevel mocked up just need to run some hardline for everything before i blast and clean up the frame.
Old 02-23-2020, 07:40 PM   #45
0ldSoul
0ldSoul's Avatar
Subscribed! That c10 is bad to the bone!! Great work, looks killer!!!
0ldSoul is offline   Reply With Quote
