06-24-2017, 03:44 PM | #1 |
Pulling LS out of Tahoe for 57 Truck
Hey all, I have a 57 truck and after going back and forth between rebuilding the 327 and finding a LS motor my dad and I have finally landed on doing an LS swap.
The 57 is in the process of getting a MII front suspension installed, rear notch, and full air ride with Accuair. Donor car is a 2005 Tahoe with a 5.3 L59 and 4L60 trans. Got the complete Tahoe for $900... quite the steal. My question is... What do we need to focus on removing from the Tahoe to make it work in the 57? Here's what I'm thinking, any additional parts we should strip would be appreciated - Motor Trans Radiator/fans Complete wiring harness/ECU Accelerator pedal Drive shaft? My list seems short in my eyes. There must be some items I'm missing that we should pull off the car before going to scrap. Appreciate the help from you guys! Pics coming soon in the 47-59 section. Thanks |
06-24-2017, 03:59 PM | #2 |
Re: Pulling LS out of Tahoe for 57 Truck
Dont forget the TAC, gas pedal and the jumper harness between the two.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-24-2017, 04:32 PM | #3 |
You might want the fuel filter-regulator setup to help build your return-style fuel system. Accessory drives, of course.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-24-2017, 04:38 PM | #4 |
Maf and o2 sensors..maybe parts of exhaust..
06-26-2017, 10:38 AM | #5 |
Trans cooler lines, maybe even all or half of the fuel lines depending on where your tank is.
Yeah, maybe cut the exhaust after the Y straightens out if you are going to use stock manifolds so you have the down pipes and Y if you want it. |
