Old 11-27-2016, 12:23 AM   #1
Electricduane
89 Burb: canoe rack recommendation?
A quick Google search indicates that several brands/types exist.
Any recommendations? Thanks!
Electricduane is offline   Reply With Quote
Old 04-04-2017, 03:17 PM   #2
Country Suburban 4x4
Country Suburban 4x4's Avatar
Re: 89 Burb: canoe rack recommendation?
I found a stock roof rack off of like a 1990 suburban and put it on my 83, looks great and original, plus it works great with a canoe. Just put a strap on the front of the canoe down to the tow hooks, and the back strap to the trailer hitch. Name:  IMG_1309.jpg
'83 GMC K2500 Suburban 4x4
2000 Chevrolet Silverado 1500 Z71 4x4
God Bless America!!!!
Country Suburban 4x4 is offline   Reply With Quote
Old 04-04-2017, 06:46 PM   #3
buffydores
buffydores's Avatar
Huge fan of factory roof rack. I have a NOS one for a Blazer ready to install. Build quality is solid. Looks period correct. Rated for 200#s.
Old 04-04-2017, 07:07 PM   #4
SilverMiner
SilverMiner's Avatar
Electricduane - I vote for the factory roofrack as well. I found one in a junkyard complete with the chrome slide strips that attach to roof ribs and the installation was very simple using well nuts to secure everything and liberal amounts of sealant to keep everything water tight. I would also recommend the rear air dam if you can find it - there is a noticeable reduction in dust on the rear window, and the dam makes a very sturdy pivot point for loading a canoe.
Country Suburban - I like the look of your rims and tires. What size are the tires if you don't mind me asking? Looks like a no-lift truck as well.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 04-05-2017, 12:02 AM   #5
No problem, my tires are LT285/75R16 Cooper Discoverer STT Pros. I am on stock suspension with no clearance issues. My truck does however have 3 leafs in the front from the factory instead of 2. (Fire department ordered it like that in '83) Here's a better pic.
Old 04-05-2017, 09:45 PM   #6
buffydores
buffydores's Avatar
Silverminer: Your burb kicks butt. Gorgeous look.
