06-05-2017, 07:22 PM | #1 |
Help before I burn the truck down.
I just installed a complete Dapper Lighting set of 575's with the halo outers and led mains. I took my time and built a nice harness, everything is wired correctly.
However' The LED Halos that also are the turn signals are firing on both sides when I chooses a turn signal. I engage the switch right or left and both right and left flash at the same time The nice folks up at Dapper walked me through a couple tests and determined my turn signal circuit suffers from "bleed" where low amount of voltage are being sent down the non chosen circuit. Less then 4 volts but that is enough for the LEDs to get triggered. It ain't enough to light up the stock bulbs or even my test light, but the meter see's it and so do the LEDs I am stumped I have no idea why there would be voltage (low as it is) in the "cold" side of the circuit. Any suggestions? |
06-06-2017, 12:23 AM | #2 | |
Msgt USAF Ret
Re: Help before I burn the truck down.
If you had a little more resistance in each light then they would not get enough voltage to light. I'm not sure how that would affect the electronic flasher though. Lowering the input voltage on the purple TS wire might drop the bleed over voltage enough to kill the cold side but still allow the hot side to work. Perhaps the electronic flasher is the wrong one for the Dapper system. I'm just speculating here. Do the two indicator lights in the dash flash together as well and are they LEDs as well?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-06-2017, 10:29 AM | #3 | |
The existing turn signals including the turn signal indicator in the dash (It is a single bulb on this truck) all function correctly perhaps the bleed is from the dash indicator or maybe the rear brake lights as there is some shared circuitry in these as well. |
06-06-2017, 11:06 AM | #4 |
My thought would be a ground issue with rear lights feeding back. The turn switch is mechanical so no contact should be made between right and left. Try pulling bulbs out of rear turn lights and see if front work correctly.
1957 3100 1950 5 window |
06-06-2017, 11:16 AM | #5 |
06-06-2017, 11:31 AM | #6 | |
As a quick check, try taking that dash indicator bulb out of the socket and chances are the problem will go away. If you can find a location for them in your cluster, changing over to dual indicators (one for each side) would probably be the easiest fix. |
06-06-2017, 06:25 PM | #7 |
FIXED
Removed the single bulb dispay in the dash. everything works great. |
