02-10-2019, 11:01 AM | #1 |
Brake pushrod to short can I swap?
Working on a 1970 3/4 ton I ordered a brake booster from Napa part #54-71011
I am installing it now and the pushrod is 1-1/2” shorter so I can’t bolt it up to the pedal. Can I swap these out? Doesn’t seem to pull out? Don’t want to damage the new one if I have to bring it back. I looked up 1ton part number and it is the same? Any help would be appreciated Trip |
02-10-2019, 01:44 PM | #2 |
Re: Brake pushrod to short can I swap?
Have you tried hooking up the vac source and starting the engine - not sure but that may move it toward where you need it.
02-10-2019, 03:38 PM | #3 |
Moderator
The rear brake booster shaft is not replaceable unless during a major overhaul...
I have seen this before... Check out https://www.napaonline.com/en/p/NBB5473709 Call the NAPA store, check their stock then take your old one to match the length..... Have fun...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-10-2019, 05:45 PM | #4 |
Yes that looks like my old one, I will order it tomorrow
Thanks for the link! Trip |
