Old 06-21-2019, 06:32 AM   #1
4u2nv
Too low
Went too low on the 82 in the front ( hacked to much spring )
I put a 3 inch drop spindle in it and should of left it at that .
Think I will start back at the stock spring and go from there AGAIN .
What and where would be a good spring ????
Thanx
4u2nv is online now   Reply With Quote
Old 06-21-2019, 07:31 AM   #2
Re: Too low
Find a set at scrap yard/Pick-n-pull. Personally I didn't like the ride of cut springs, especially if I took out more than a coil. Far as I know, springs from any 70-87 will work.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Palf70Step is online now   Reply With Quote
Old 06-21-2019, 08:48 AM   #3
rpmerf
rpmerf's Avatar
Re: Too low
Rock auto has springs for relatively cheap. If you are going to cut them, you might want to use heavy duty springs. This way the increased spring rate makes up for the lack of suspension travel. This way it takes the same force to bottom out the suspension.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 06-21-2019, 03:34 PM   #4
Loco83
Loco83's Avatar
Re: Too low
2 spring cut on my 83 and it rides pretty nice, thought about adding 2" dropped spindles but that might be too low
Loco83 is offline   Reply With Quote
Old 06-21-2019, 04:18 PM   #5
Tom
driving is in my blood
Tom's Avatar
Re: Too low
Lowered springs are like $100 why waste all this time instead of doing it right?
-02 Suburban 4x4: stock
Old 06-21-2019, 04:41 PM   #6
sweetk30
selective wrench turner guy
sweetk30's Avatar
Re: Too low
2nd rockauto for new stock units . why waste time with used 30+ year old springs for the time and energy to swap them .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is online now   Reply With Quote
Old 06-22-2019, 09:35 PM   #7
Ziegelsteinfaust
Re: Too low
I like lighter duty C20 springs in dropped trucks
Ziegelsteinfaust is offline   Reply With Quote
Old 06-24-2019, 04:20 AM   #8
bbbc10
Diggin The SquareLife
Re: Too low
get hd springs an cut them
bbbc10 is offline   Reply With Quote
Old 06-24-2019, 09:49 AM   #9
rpmerf
rpmerf's Avatar
Re: Too low
Very interesting thing I noticed.
Compared coil springs between a 1982 C10 and C20 with a 350. Standard duty and heavy duty are the same between C10 and C20.
Comparing 1970 coil springs, C10 heavy duty springs are the same as C20 regular duty springs.
1997 GMC Suburban
Old 06-24-2019, 07:36 PM   #10
4u2nv
Re: Too low
I wouldn't be surprised that this 82 has the original shocks on it , would a set of new good shocks help on the ride maybe !!!!
What's a good shock ??? for the front
Old 06-25-2019, 12:55 AM   #11
layinrocker65
layinrocker65's Avatar
Re: Too low
Get some big block springs from rockauto and then cut one coil. I had worn out stock coils that I cut. Rode terrible and truck still had an obvious lean to the drivers side. Got some big block coils from rockauto and cut them. Rides way better and is level side to side now. I also put on some shorter bump stops and I couldn’t be happier.
This was all with my 2.5” spindles
For shocks, I got summit drop shocks.
53 GMC 2.5 ton COE
70 Chevy C10 LWB 350/465(soon to be 6.0/4L80e)
74 Chevy C10 SWB 5.3/4L80e
91 GMC Syclone 370/4L80e PT88 AWD
92 GMC Typhoon 6.0/4L80e twin 65s AWD
07 RCLB Sierra Duramax
15 Chevy SS 6.2/TR6060 LSA blower
layinrocker65 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
