Old 03-04-2018, 08:45 PM   #1
thebeerbaron
How did I strip this shock mount?
Where did I go wrong?
72 3/4 ton, rear upper shock mount nut (leaf spring). Took the torque spec from this post:
http://67-72chevytrucks.com/vboard/s...9&postcount=16
EDIT TO ADD: Name:  Screen Shot 2018-03-04 at 6.09.33 PM.jpg
Upper shock mount is 7/16-20. Torque specs for that bolt size are about half the spec above. See http://www.almabolt.com/pages/catalo...ningtorque.htm
EDIT TO ADD: Name:  Screen Shot 2018-03-04 at 6.09.43 PM.jpg
I completely stripped the upper shock mount stud before I got anywhere near 140ft-lbs. (see attached pic)
Is the GM spec just plain wrong? Should I just be going with the spec-by-bolt-size instead?
Thanks,
Peter
Last edited by thebeerbaron; 03-04-2018 at 10:12 PM. Reason: Added pics to supplement links
thebeerbaron is offline   Reply With Quote
Old 03-04-2018, 09:04 PM   #2
mongocanfly
mongocanfly's Avatar
Re: How did I strip this shock mount?
in that first link you posted it says 65lb front and 140lb rear for leaf spring and 70 for coil spring......i would have thought they should be the same...I'm thinking 65-70 is plenty...140lb sounds like way to much for 7/16...
the 2nd link don't work...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-05-2018, 07:45 AM   #3
PGSigns
PGSigns's Avatar
It looks be referring to the shock mount to the frame and not the shock to the mount. They just get pulled up tight. The 58 is a much better number.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
