07-11-2019, 10:45 AM | #1 |
Sail panels, deluxe heater control , & more
Sail panels - driver quality with some scratches and dings, one screw hole broke. $75, Sold
Deluxe heater control with cables and harness , no broken levers , good knobs . $80 sold 1962 Aluminum headlight bezel, driver quality with some small dents and dings around the bottom $50 RV junior mirrors- plenty of patina, one head cracked . $75 Sold 1966 1/2 ton clip type hubcap. Rough condition $15 Gas filler neck-$30 Cowl / kick panel vents- good condition, some surface rust , gaskets still good. $60 Steel upper rad hoses-$40 ea V8 upper rad bracket with rubber cushions -$50 sold Glove box door. -$30 All prices are plus shipping. Last edited by southern parts; 11-25-2019 at 01:10 PM. |
07-11-2019, 10:48 AM | #2 |
Re: Sail panels, deluxe heater control , & more
Few more pics
07-11-2019, 10:59 AM | #3 |
I'll take the better of the two steel upper radiator hose/pipes. Will send you a PM.
07-11-2019, 12:16 PM | #4 |
i'll take the heater control.
07-11-2019, 12:58 PM | #5 |
I will try to get some totals with shipping this evening when I get in from work
07-11-2019, 03:49 PM | #6 |
Man, been looking for some upper radiator steel tubes =/
Matk me second if it doesnt fall thru . . .
dont want to hear excuses, i want to hear solution(s) |
07-11-2019, 04:04 PM | #7 |
But Found Her 25yrs Later!
I think he said he has two.
07-11-2019, 04:46 PM | #8 |
Yes , I have 2.
07-11-2019, 05:07 PM | #9 |
I will take the upper radiator bracket for V-8, if it is correct for 64 year. Thanks
07-12-2019, 10:14 AM | #10 |
I little closer look at both steel upper rad hoses . both have some pretty bad pitting and rust, probably not worth taking a chance on
pimpston65 and chtr65 I can fit both your parts in med. flat rate boxes. sending pm`s shortly |
07-12-2019, 11:35 AM | #11 |
Too bad on the upper radiator pipes, appreciate you checking them out closely.
07-12-2019, 02:51 PM | #12 |
payment sent.
07-12-2019, 02:54 PM | #13 |
that part of the metal rad pipe is in the rubber part of the hose, it should still work and not leak. just my 2 cents
07-12-2019, 03:12 PM | #14 |
07-12-2019, 06:46 PM | #15 |
If you decide one of the radiator pipes is beyond usable, I might be interested in trying to create a cad template from it that someone could take down to the muffler shop and have one bent out of stainless.
07-17-2019, 11:00 AM | #16 |
Winston, the heater control is on the way. You might even have by now.
07-17-2019, 12:06 PM | #17 |
07-17-2019, 03:47 PM | #18 |
Are both radiator pipes sold?
07-17-2019, 07:21 PM | #19 |
LostMy65- no, I still have one.
07-17-2019, 09:54 PM | #20 |
Did you say it was pretty rusted?
Would you do $40 shipped?
07-18-2019, 11:05 AM | #21 |
It's pitted on both ends. Let me see how much shipping will be.
07-20-2019, 08:27 PM | #22 |
Payment sent.
08-02-2019, 09:10 PM | #23 |
Bump
08-04-2019, 12:16 AM | #24 |
I like to see more pick of the glove box door ..shipped to 95407 ?
There is more then one way to do it right ! |
08-06-2019, 07:44 PM | #25 |
I will take the glove box door ,shipped to 95407
