Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-16-2023, 10:59 PM   #26
ghackett1
68 C10 Longbed
ghackett1's Avatar
Re: Strip to bare metal or not
Originally Posted by 7D2N View Post
ghackett1. I did mechanical sanding to the areas that needed work, did you sand or use a chemical product?
I use both methods. On the truck pictured I mechanically stripped the paint off.
ghackett1 is offline   Reply With Quote
Old 12-02-2023, 12:20 AM   #27
chris mc bride
chris mc bride's Avatar
While far from knowing what I am doing.I have worked around lil brother in his body shop.I am planning to strip to bare metal,one section at a time. Fix anything I find a prime with quality sealer. Then do another when money and time allow.Once all done sand and prime all for paint.More work but will assure I find all problems.
No way would I just scuff and hope. JMO
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 01-27-2024, 10:55 AM   #28
raggedjim
raggedjim's Avatar
I stripped one of my trucks down about 20 years ago. It had 7 (SEVEN) different colors of paint on it! The only reason I painted it was I didn't like the color. Scuff and paint used to be the standard, and if you had looked at that truck you would have never known it had that many layers.
Times and methods change. Lately we're all building trucks to last forever (good thing) but it comes sometimes at the simple joy of doing the best you can. Perfect is the enemy of good enough.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-27-2024, 01:37 PM   #29
7D2N
7D2N's Avatar
Thanks Jim that's the way I'm looking at it. I'm working on the doors and fenders now and way more work than I would have thought. Planing to paint this summer.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 01-27-2024, 06:05 PM   #30
LS short box
Don't know if it would for you but I use a 30LB pressure sand blaster from HF to clean up all edges.
Pic of my 68 parts prior to epoxy prime.
LS short box is online now   Reply With Quote
Old 01-28-2024, 12:51 PM   #31
raggedjim
raggedjim's Avatar
By the way, the dash came out great!
Roger
'70 GMC Jimmy 2wd
Old 02-03-2024, 09:12 PM   #32
7D2N
7D2N's Avatar
Working on the fenders and the doors.
Old 02-03-2024, 09:30 PM   #33
7D2N
7D2N's Avatar
And the doors
Old 02-03-2024, 09:50 PM   #34
7D2N
7D2N's Avatar
Thanks, just a rattle can mix from the paint shop.
Old 02-10-2024, 01:33 PM   #35
7D2N
7D2N's Avatar
I have the interior side of the doors in primer, also repaired the rock chips on the front of the hood. I don't like not being able to sand outside it makes a mess in the garage.
Old 02-10-2024, 02:04 PM   #36
raggedjim
raggedjim's Avatar
I like working out on the front porch of my shop, but today it's raining so I'm putting a thin layer of dust on everything inside. I will need to spring clean at some point.
Roger
'70 GMC Jimmy 2wd
Old 02-20-2024, 03:27 PM   #37
richards72chevy
richards72chevy's Avatar
Looks like a clean blazer I would be more worried about the areas I couldn't see.
richards72chevy is offline   Reply With Quote
Old 03-17-2024, 06:46 PM   #38
7D2N
7D2N's Avatar
I have the primer on the repairs.
Old 04-02-2024, 08:50 PM   #39
7D2N
7D2N's Avatar
Yes sir, lots of areas I could'nt see but from doing panel replacement and metal repairs the unseen I think it will be ok.
Old 04-02-2024, 08:58 PM   #40
7D2N
7D2N's Avatar
I posted this in another section, but next time it comes apart its for finish primer and paint.
Old 04-07-2024, 11:15 AM   #41
Myself
Twice I have not stripped to metal........and twice it bit me in the a$$.
Myself is offline   Reply With Quote
Old 04-08-2024, 06:10 PM   #42
kev2809
low n' slo
kev2809's Avatar
progress is looking pretty good from here...nice work
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-17-2024, 08:15 PM   #43
7D2N
7D2N's Avatar
Thank you. The blazer was repainted in 2005/2007 in Utah by whom I have no idea but its a pretty dry state. I going to move forward but do you guys think that the states with higher humidty may have more problems for DIY guys.
Old 04-18-2024, 12:54 AM   #44
ProjectDD
Cars can sit for years in bare metal and not flash rust if kept in a climate controlled environment and people keep their oily fingers off of it. A damp, high humidity garage isn't ideal. I'm in PA and we get pretty high in humidity at times. Cars at a prior shop I worked at had been sitting in bare metal for 5+ years. As long as you give it a fresh scuff/sand prior to epoxy, you'll be good. I would say this mainly applies to mechanically stripped to bare metal. Sandblasted metal will flash rust much quicker and should be epoxied asap. If you sand down to bare metal while fixing dents, don't sweat it and epoxy at your convenience. Providing your garage isn't like 70% humidity 24/7.
ProjectDD is offline   Reply With Quote
