Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 08-19-2019, 10:04 PM   #276
OutlawDrifter
Re: 97 3500 454 4x4 project
Originally Posted by Stormin08 View Post
is that HIS cluster ? that is a pre 95...89-94 basically, most pre 92 didnt have the tach...i have one laying around, and guys try to find them.
The cluster pictured is most certainly not pre 95.
Always nice to come up with spare parts!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-20-2019, 07:12 AM   #277
Stormin08
Stormin08's Avatar
i didnt realize they were that close with the bezel removed, i would have pictured a more curved surround.
Stormin08 is offline   Reply With Quote
Old 08-20-2019, 01:17 PM   #278
mingoman
It's already in my truck too. There must be something amiss with my original cluster. It didn't have any lights working when I bought it and after changing them out I still didn't have any. I swapped clusters and it lights up like a blue Christmas tree now.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 08-20-2019, 02:40 PM   #279
Joseog83
Joseog83's Avatar
Your truck has come a long way, Looks Awesome! Nice Work!
Joseog83 is offline   Reply With Quote
Old 09-08-2019, 05:07 PM   #280
mingoman
Thanks!
76/77/78 Cheyenne
Old 09-08-2019, 05:18 PM   #281
mingoman
I've ran my cable back and mounted the camera. Going to have to pull the radio and dbl check the connections, it goes to the backup screen when I put it in reverse, but I dont have a picture.
I mounted the bumper on first, obviously, modifying the original brackets so I could use the extra two bolts for my hitch. Changed out the license plate bulbs with led light while I was at it.
I still have to decide on the lights to use in my front bumper and find a factory auxiliary switch to use too.
My plan is still to finish up the few more things I need to do before I swap engines.
Its getting there.
76/77/78 Cheyenne
Old 09-09-2019, 11:12 AM   #282
mingoman
Camera was an easy fix. Apparently I needed to hook the power up directly to the power terminal under the hood. Once I did that I had a camera.
I'm going to center the bed up and bolt it up today, still just has 2 bolts in it, and button up a few things before starting on my front bumper lights.
I threw the sunset gmt400 pic just to brighten everyone's day!
76/77/78 Cheyenne
Old 09-09-2019, 05:57 PM   #283
mingoman
Much better than the may pops I had on.
76/77/78 Cheyenne
Old 09-10-2019, 09:09 PM   #284
mingoman
Time for another medical post. A lifetime in the great outdoors should include a big straw hat, long sleeve shirt, and sunscreen apparently. Had a basal cell carcinoma cut off today. I did get home in time to clean and install the truck storage box I picked up last week, however, with the heat still on around here I didn't really do much else today.
Cover up out there folk and if you notice a spot that bleeds for no reason, even if it doesn't resemble what you typically picture as skin cancer, get it checked!
76/77/78 Cheyenne
Old 11-04-2019, 05:23 PM   #285
mingoman
Off nights this morning and had a chance to check out the pick and pull. I scored a fog light switch with the pigtail, a 3/4 ton jack plus all the accessories, and an ash tray for the back for 12 bucks.
They had a set of Escalade panels minus the drivers side I thought about, but didn't know how hard that would be to find or the switch inserts that were gone.
The steering wheel was there, but less than stellar.
76/77/78 Cheyenne
Old 11-04-2019, 09:42 PM   #286
Wide Open
Cool
Wide Open is offline   Reply With Quote
Old 11-20-2019, 04:05 PM   #287
mingoman
https://youtu.be/fUoPmhuP6NU
Finally got a chance to do a little more on my truck. Following 88 GMC's instructions I made a harness to make my tow mirrors work when the parking lights are on as well as turn signals.
I took a short video of them working and uploaded it so everyone can see if they'd like.
I still need to tuck the harness out of the way, but I'm happy how they work.
Next on the list is mount my lights in the bumper and wire them up to my Escalade fog light switch.
76/77/78 Cheyenne
Old 11-20-2019, 04:24 PM   #288
mingoman
This is online, but I'll add the diagram for the harness I used here too.
76/77/78 Cheyenne
Old 11-29-2019, 10:47 AM   #289
mingoman
https://www.superbrightleds.com/more...ns/1930/12977/
These are the lights I ordered for my bumper. 15% off is always nice too.
76/77/78 Cheyenne
Old 12-13-2019, 01:03 PM   #290
mingoman
My lights finally came in, they were on backorder.
76/77/78 Cheyenne
Old 01-07-2020, 05:17 PM   #291
mingoman
Back on my truck after being pretty tied up with Christmas and family.
I took most of the day making brackets out of some reasonably heavy for the task aluminum.
I'm going to go back and paint the brackets black, I don't like them showing through the bumper.
Also, one of my distractions has been the planter I bought. I've been wanting a 2 row planter and had the chance to buy an 8 row cheap. A friend of mine and I are going to make 2 planters from it.
I cut it in 3 sections and hauled the first load off yesterday.
Really could have used the ton truck.🙄
76/77/78 Cheyenne
Old 01-08-2020, 07:57 PM   #292
mingoman
I still have to hook them up in the cab, but I wanted to see how they looked after getting the harness ran. These things are bright.
76/77/78 Cheyenne
Old 03-14-2020, 06:59 AM   #293
mingoman
Made its 1st trip to the farm yesterday. The starter went out on my other truck and since I had to get the last of this years trees planted, it was pressed into service. I did pull the new tires off the front before I left, still need to align them and I didn't want to wear the new ones. I'll see about that next week.
76/77/78 Cheyenne
Old 03-14-2020, 08:02 AM   #294
It looks good Mingo! I have always though the 95-98 GMC front end looked sooooooo good!
Old 03-14-2020, 12:56 PM   #295
mingoman
Thanks!
76/77/78 Cheyenne
Old 03-18-2020, 09:30 AM   #296
OutlawDrifter
Glad you're putting it to use!
1991 Z/28, 6.0L/T56
Old 03-18-2020, 12:50 PM   #297
mingoman
Rainy day here, seems like a good time to get that alignment.
76/77/78 Cheyenne
Old 04-12-2020, 05:31 PM   #298
mingoman
2k and a rebuild later and we have overdrive!
Planetaries and the input shaft were shot.
76/77/78 Cheyenne
Old 04-12-2020, 06:44 PM   #299
OutlawDrifter
Right in the fat spot of the power band!
1991 Z/28, 6.0L/T56
Old 04-21-2020, 01:26 AM   #300
Liz
Catchy title goes here..
Liz's Avatar
Absolutely love this truck. I had a 96 white dually new. One of my favorite vehicles to date.. minus the spindle issues.
Liz is offline   Reply With Quote
