03-29-2019, 10:02 AM | #1 |
Questionable
Fuel Spider -> Anything else to change while there?
'98 Sierra 5.7L
89,500 miles I have no maintenance records before 80K miles Technically not running rough. "OK" throttle response. Oil pressure sender jumpy. No visible top-end leaks. If budget was unlimited and I'm in the top end replacing the spider, what's worth doing at the same time? So far from digging on posts over several hours, I've read:
Anything else worthwhile? Note: I don't have any coolant leaks or gurgling sounds at the heater core.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-29-2019, 10:13 AM | #2 |
Re: Fuel Spider -> Anything else to change while there?
I would not replace it until it gives you trouble. I have maintained many 5.7 votecs with well over 200 & original spiders. I personally own 2, one with 290 & one at 305 & both have original spiders.
Now, intake gaskets, that's another story! |
03-29-2019, 08:52 PM | #3 |
Listen and learn my padawan...LOL
You have to remove the coil and the ICM from the intake at that time. You could decide to change the coil at that time. The ICM is mounted to the heat sink plate using white heat sink compound. After years, the heat sink compound dries up. It is the best time to remove the ICM, clean both it and the plate with alcohol and reapply fresh heat sink compound.
DO NOT CONFUSE DIELECTRIC GREASE WITH HEAT SINK COMPOUND. You have everything correct except for the spider it self. All those spiders regardless of who's name is on them, are made by Standard Motor Parts. Shown here: https://www.summitracing.com/parts/smp-fj504/overview/ Even if you found them for less on Amazon, I still wouldn't buy them there. Those are usually third party companies and you don't jack $HI+ about their return policy or warranty or anything else. Stick with a company like Summit. They will always do you right. The other important thing you already picked up on was the steel intake gaskets. They are the only cure for what ails these engines. Other then the damn distributor correct o cap. POS. I was almost with the other guy in saying don't change it till it needs it but with one exception. If your engine has the original plastic intake gaskets, they will go first and at that point you could change the injector assembly. However, if an injector goes bad and floods the cylinder with too much fuel and washes the cylinder walls and causes scratching. Ooops too late. But guess what, I've had one of these new assemblies go bad and dump fuel so there really is no real insurance. It comes down to what gives you piece of mind. I'll leave you with 3 points of thought. First you can do the injector change with out removing the bottom half of the intake from the heads. Thus not touching the intake gaskets at the heads. Another is if you do remove the bottom half of the intake, when you replace it, torgue it in 3 steps. Kinda like a 1/3 a 1/3 and a 1/3. It doesn't have to be exactly a 1/3 each time but take a few steps to get there. If my old mind is correct, the torgue is something like 11 ft*lbs. You use the inside out progression of tightening as usual. Last, you want torque to be as close to the center of the range of a torque wrench as possible. The closer you get to the ends of the torque range, the less accurate it is. So if you can switch out torque wrenches for something different, do it. For example 11 foot pounds is 132 in lbs. See where I'm going with this? |
04-06-2019, 09:39 AM | #4 |
Still plays with trucks
On the 4.3 SPFI engines with the similar spider injector system and plastic poppet valves they put the fuel pressure regulator inside the intake plenum. They are known to leak fuel when they go bad and it will cause fuel economy and tuning problems. I had to replace mine on my 95. Originally thought it was the spider injector assembly that was the problem but that turned out to be good. Replaced the regulator alone after seeing it was obviously leaking along with the in the plenum fuel hoses and it was running better than ever.
I don't know if the V-8 version has the same in the plenum fuel pressure regulator setup as the 4.3 SPFI engine but I thought it was worth mentioning as something to look for in case it does.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
04-17-2019, 03:43 PM | #5 | |
04-17-2019, 10:23 PM | #6 |
The new injector(updated or poppet) will come with a new regulator already installed onto it.
04-18-2019, 03:00 PM | #7 |
Who Me?
I replaced two of these in the last few years. One on a 5.7 and one on a 4.3. I went with the updated model on both. I also changed the fuel filter.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
04-18-2019, 04:07 PM | #8 |
True. Didn't even think about that. I replaced my FPR while sorting through the diagnosis process only to realize it was included w/the new Spider module assembly when I ultimately replaced it.
04-27-2019, 04:04 AM | #9 |
I did a "Delphi" spider upgrade that has 8 actual little injectors on my '97 5.7 (after my wife ran it hot from not looking at the gauge, and then NOT TELLING me after.. Pouring coolant from intake gasket sagging past the water port into lifter valley due to the overheating.
..Anyhow, It started within 3 rev's and ran VERY smooth right off. Great throttle response to. Remember to check or replace the o2 sensors. If they go bad with this crappy gas it funnels bad EGR gasses back in the intake. (you'll notice lots of black soot/carbon deposits if you take the intake apart. I had to use a drill and die grinder to clear the EGR port!! but the o2 sensors looked 'clean'..?) Then get on Youtube and search for the BIG-3 Wire grounding. It will all help with your ignition of the fuel even if you don't do the spider swap. https://www.partsgeek.com/hz45xn3-ch...+Fuel+Injector Hope it works. E |
04-27-2019, 08:03 AM | #10 | |
