07-12-2015, 11:33 PM | #1 |
Deep lip 22's
Hello, I was needing help with rim specs. What's the deepest lip you can have in a 22 inch rim without narrowing the rearend? I'm sure it would be a 22 x 10 or 22x11 but what would be the specs....like back spacing and or offset? This would be for the rear. The truck is a 86 bagged but doesn't lay from cause I didn't want to cut the bed up. Thanks ahead of time for any help!
07-13-2015, 09:54 AM | #2 |
Re: Deep lip 22's
5" back space w/o narrowing the rear.
07-13-2015, 10:06 AM | #3 |
Re: Deep lip 22's
Thanks for the response. With the 5" backspacing how much lip would that give me you think?
07-13-2015, 10:44 AM | #4 |
Re: Deep lip 22's
10" wheel w/5" bs = 5" lip. 4" bs would be deeper but will be very close to the lip of the wheel-well opening.
