01-27-2018, 10:15 PM | #1 |
Upgrade my stock 350 for torque.
My '68 has a 195/260hp GM Crate Engine from 2013 in it. I swapped on a Performer Intake and 1405 carb. It runs good, gets OK mileage, pulls well, hell even spins the tires occasionally. I did a quick GPS 1/4 mile test and it did a high 14 at about 85. Not bad, really. But.... I want it to pull harder.
My real world expectation... I don't really go over 4k rpms, ever. So torque is way more important than hp. I want to upgrade the long block with a cam / lifter kit that will maximize low end torque, and if it runs out of steam at 4500, no worries. I have stock ramhorns and pretty happy with how they sound and work. I looked at a COMP grind SK12-206-2, (https://www.summitracing.com/parts/cca-sk12-206-2) that seems good. I also saw the COMP CL12-210-2 (https://www.summitracing.com/parts/c...10-2/overview/) that seems good, but not sure that it might be too much for my small stock iron heads. I want to keep with in budget, so $250 for a cam swap is about right. Anyone have any experience with either of these or similar spec grinds for torque? |
01-27-2018, 10:49 PM | #2 |
Re: Upgrade my stock 350 for torque.
I've put the Summit Racing 1103 cam in two 350's now and could not be happier. I currently run that cam with one of the cheap Summit Racing torque converters (2,300-2,600 RPM stall) and could not be happier. I run it with Vortec heads and a Weiand Stealth (two plane, like your Performer) intake and a 1406 Edelbrock carb. That truck weighs 3,640 lbs curb weight, without me. Cam broke in perfectly, even with a couple of hiccups during the break in process. The 1103 cam reports a power range between 1,600-5,200. If that is a little higher than you want your power band to be, the 1102 cam from Summit looks good and has good reviews. It's power building range is reportedly between 1,500-4,000 RPM. Either way, I don't think that you can beat those cams for the money, each priced at $62, or $100 for the kit that includes new lifters, which you will NEED when swapping your cam.
Good luck! Nik
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
01-27-2018, 10:53 PM | #3 |
The 440 lift cam will give you better low end performance.
01-27-2018, 10:55 PM | #4 |
I think that you're doing REALLY well if you're already getting that thing 1320' in 14 seconds from a stop, with an otherwise stock engine and transmission.
01-27-2018, 11:12 PM | #5 | |
The 440 cam does sound better. The 260 duration should keep the torque peak lower. 278/288 seems high. My cam is a puny 194/204 @ .050 right now at like .400" lift... so any of those will wake it up! |
01-27-2018, 11:28 PM | #6 |
The 700r4 will certainly help, with the lower first gear!
01-28-2018, 12:38 AM | #7 |
Yea, it has the usual drawbacks but the OD was needed so I could use it long distance. Started out with a TH400 and 2.48 first, but a $200 700r4 in good condition was too good to pass up. They don't like to downshift from OD, but I tweaked it so it will at full throttle.
Anyway, thanks guys for the info! Pulling the truck apart here to paint in the next month or two, so doing some upgrades while I have easy access. |
01-28-2018, 04:44 PM | #8 |
A set of vortec heads would probably do more than a cam swap.
01-29-2018, 05:52 PM | #9 |
With the SBC that I had in my old CJ5, I used an Isky cam with a 208/216 duration at .050. It had awesome torque.
https://www.summitracing.com/parts/i...7012/overview/ Powerband is wrong in the description - it was done before 5000rpm.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
01-30-2018, 11:39 AM | #10 |
Doesn't sound like you'd like to do anything with the exhaust, however don't underestimate what a set of long tube headers can do. Yeah they are a little noisy compared to the ram horns. As far as cam I'd have to vote for the 1102 cam with stock heads. Maybe look at some rockers as well
02-01-2018, 05:03 PM | #11 |
driving is in my blood
I've never found a 350 lacking torque. They are gutless HP wise stock but torque? They can tow more then the truck is rated for. Guess I've driven non trucks too much, now that's lacking torque.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-03-2018, 06:32 PM | #12 |
+1
Also, replacing heads and cam would be a couple of good upgrades to make at the same time! But, that also snowballs into buying a new intake manifold, since the Gen 1 SBC intake won't work on the Vortec cylinder heads.
02-03-2018, 06:41 PM | #13 |
I'm interested in doing a similar set up. Let us know what you decide/how it works out.
02-04-2018, 12:12 AM | #14 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I did a rebuild on a stock 72 350 four years ago for my 72 C/10 and was looking for a cam for towing an occasional 7000LB tandem trailer. I went with the Lunati Voodoo 256/262 cam/lifter kit, http://www.lunatipower.com/Product.aspx?id=2323&gid=287 and I couldn't be happier! Still pulling like a train! I added an Edelbrock 2101 with the factory 4MV Quadrajet and Hedman long tubes. Bone stock heads and pistons with MSD HEI...PS. 14.9 aint bad!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
02-12-2018, 11:34 AM | #15 | ||
02-12-2018, 02:12 PM | #16 |
Check out Engine Masters on YouTube. They do a lot of comparisons on small block chevys.
Cam comparisons. Headers vs. Manifolds. Intake manifolds. Roller vs flat tappets EFI vs Carb All kinds of cool stuff and they dyno all of it. just something to check out. Last edited by Keystone_Hate; 02-12-2018 at 05:40 PM. |
10-18-2018, 07:01 PM | #17 |
But Found Her 25yrs Later!
Updates?
10-19-2018, 12:35 AM | #18 |
I just built this motor.
I used 72cc swirl port TBI heads. They make good low end torque and do nothing over 4500rpm Mtc1 cam :high lift short duration good low end torque Flat top pistons 9.25:1 compression Cast iron manifolds, 2.5" dual exhaust with an H pipe Hei and a Q-jet That is a low end torque combo. ...at least I hope so. It's still setting on the engine stand. |
10-19-2018, 12:30 PM | #19 | |
I have 2.5 rams horn exhaust manifolds and don't want headers. I very rarely drive over 55, and 90% of the time 45 mph max. And I drive a maximum of 6000 miles a year. The gm goodwrench I have is very low miles, so I'm wanting to do low cost upgrades to make it as best suited as possible for daily driving.
10-22-2018, 08:07 PM | #20 | |
