12-21-2016, 07:22 PM | #1 |
ride tech -kit for c-30 info ??
anybody install a ride tech rear air kit on a 74-90 c-30 1 ton dually truck ? im looking for a used kit and or pics of this kit installed -im trying to drop the rear of my p-30 bus frame ? i seen on line a place called "bones fab" did one and looks like part of the kit gets a weld in crossmember ?? i cant seem to get much info from "ride tech " of coarse i want a non company opinion of installation and after comments ?? i suppose i need to contact this bones fab and see what his is -sure looks good on line !! any help guys ?? thanks
12-21-2016, 11:34 PM | #2 |
Re: ride tech -kit for c-30 info ??
I have a modified version of the original 'bolt-in' Square body C30 HD Airbar set-up. Not much wasn't tweaked on mine but there was no 'weld-in' for that kit as it was intended to be all bolt-in.
They now offer the 'universal' weld-in install kit that's not specific to any year model.
12-24-2016, 09:44 PM | #3 |
Are you looking for something bolt in or weld in ?
12-26-2016, 01:24 PM | #4 |
56 - autocross
I know Bones. He is great. I am sure he would share some info with you. Call him. Perhaps he will even make u parts you might need.
