Old 12-28-2016, 01:26 AM   #1
a32axo
Need help with front suspension disc brake swap!!! Please!
So im swapping on a front suspension crossmember from another c10 truck dont know what year but the guy i purchased it from said it was from a c10. I have a 1970 c10. The holes match up to bolt on to frame the problem im having is that the lower A arm is going to hit the headers, how can i fix this problem. Newbie here. here are pics.
a32axo is offline   Reply With Quote
Old 12-28-2016, 03:23 AM   #2
andrewmp6
Re: Need help with front suspension disc brake swap!!! Please!
Go a head and fully install that ifs and see if they hit or not.If they hit you can run shorter headers or you'll have to dent your headers for clearance.Some people will say don't do that it will cost you power but its been proven on engine masters on a dyno it won't hurt at all.
andrewmp6 is offline   Reply With Quote
Old 12-28-2016, 03:29 AM   #3
a32axo
It's definitely going to hit I measured and the the stocks ones are 17 inches and the ones I'm installing are 20 inches. Do they bend im thinking of going to a muffler shop and seeing if they can bend them, if not I think m I'm going to have to go to shortys
Old 12-28-2016, 07:48 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
The easiest and most sensible thing to do it what I do with every truck I bring home.......Remove the headers, Im sure they leak anyway, throw them in the scrap metal pile then re-do your exhaust with 2.5 manifolds after you install the clip.
All jokes aside (not really), pulling the exhaust is probably the way to go, the clip HAS to go where it is going to land.The exhaust is adjustable in many different ways. You can alter the headers, go with shorties or as mentioned, do manifolds.
Good luck though....its always frustrating when you encounter an unforeseen glitch.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 12-29-2016, 03:03 AM   #5
andrewmp6
72 freak cheap headers and headers not retorqued after a week will leak.
Old 12-29-2016, 07:38 AM   #6
72freak
72freak's Avatar
All headers leak, but yes, the above statement is 100% accurate!.
Old 12-29-2016, 09:39 AM   #7
a32axo
How can I dent the headers they are hedmans
Old 12-29-2016, 10:31 AM   #8
Willie Makeit
Willie Makeit's Avatar
weird, i've got a set of headers on a supercharged LS and they were torqued to spec when originally installed, have never been retorqued and don't leak. mine must be defective.
Willie Makeit is offline   Reply With Quote
Old 12-29-2016, 03:19 PM   #9
panhandler62
Java Mechanic
panhandler62's Avatar
Depends on the headers... With the $100 cheapies it's a weekly maintenance job...
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 12-29-2016, 03:33 PM   #10
biketopia
Maybe your motor mount is toast, saggy and what not causing you engine to lean and causing the interference. I'd pull the header and install the front end and then re-evaluate the other pieces of the puzzle that can be moved. I, like many others have installed headers and did not run into this problem. Also shock length wont have a thing to do with a arm placement, unless they are massively under or over sized not letting the suspension move.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-29-2016, 03:37 PM   #11
a32axo
Originally Posted by biketopia View Post
Maybe your motor mount is toast, saggy and what not causing you engine to lean and causing the interference. I'd pull the header and install the front end and then re-evaluate the other pieces of the puzzle that can be moved. I, like many others have installed headers and did not run into this problem. Also shock length wont have a thing to do with a arm placement.
This is where it hits. Stock lower a arms are 17 inches wide these are 20
Old 12-29-2016, 03:42 PM   #12
a32axo
So maybe if the engine sat a little higher it wouldn't hit or more towards the rear
Old 12-30-2016, 08:36 PM   #13
PGSigns
PGSigns's Avatar
I have those A arms on my 66 with no problems. I also did the caster mod that gave me another 1/2" of room. You can trim the washer to gain some more room. Pull your headers and do the swap (you can just swap the a arms). Then see where the headers hit and make a plan from there.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
