Old 04-28-2018, 07:36 AM   #1
NC_John
NC_John's Avatar
No Limit R&P Steering Shaft Angles
Has anyone who installed the No Limit rack and pinion had any issues with steering shaft/u-joint angles?
I've installed it in my 70. Did it by the book. Moved the engine back to the rear mounts. Bought the recommended ididit shortened column specifically for the rack and pinion setup. Didn't deviate from the instructions whatsoever.
Problem is my u-joint down where the long shaft goes to the short section at the frame has such a sharp angle it has tight spots. I cant figure out why or what I can change/adjust to correct it. I'm thinking the solution might be to get a double u-joint but then I need to support the long shaft off the frame.
I want to measure my angles at the joint but didnt think to do it before I put the inner fender back in so now its going to be a pain to do so.
Anybody else had this issue or is this just another thing on my truck that is somehow different from all the others?
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 04-30-2018, 07:13 PM   #2
robnolimit
robnolimit's Avatar
Re: No Limit R&P Steering Shaft Angles
can you post some picts? maybe we can help.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 04-30-2018, 07:35 PM   #3
NC_John
NC_John's Avatar
Here is one I have Rob. Let me know what else you need to see.
I can't adjust the angle of the column, nor can I adjust the angle of the shaft coming up from the R&P through the frame. Not sure why I am having this issue.
1970 C-10 LWB "Blu"
Old 05-01-2018, 06:48 AM   #4
PGSigns
PGSigns's Avatar
John I ran into this a couple of time doing drag cars and what I found was just a little core shift on the jount bodies causing a little more material on one side. As the angle got up they would just rub. Marked where they touched with a sharpie and took a tiny bit off with the grinder. Worked fine after that.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-01-2018, 08:59 AM   #5
robnolimit
robnolimit's Avatar
looks pretty good. These U-joints can go to 30 degrees OK. check to make sure the shafts are not protruding into the U-joint center, and touching. Also, I know the set screws are sometimes an issue. One long/one short. I usually cut the long one down to match the short. Make sure the set screws are not rubbing on the frame/mount bolt when rotating the steering. Last, check PG's solution. I have also fixed many steering issues with some light clearancing with a Dremel tool. Please let us know what the solution is. Thanks.
Old 05-01-2018, 12:26 PM   #6
NC_John
NC_John's Avatar
Jimmy
Yeah, I did a little of that on the u-joint down at the frame. Just didn't think it should have been necessary. I may have to do a little more because I can still feel tight spots when turning.
thanks!
1970 C-10 LWB "Blu"
Old 05-01-2018, 12:31 PM   #7
NC_John
NC_John's Avatar
I need to measure the angles between the two shafts- something I should have done prior to installing the inner fender but oh well.
I do have the shafts flush in the u-joints- I was careful to do that on installation.
I did get rid of the long set-screws and installed shorties so I know it's not that.
I may clearance the lower u-joint some more but am just surprised/disappointed that it's necessary. Something about this truck... Nothing ever goes easy. Its always got to be the hard way.
I'll let you guys know how I resolve it when the column goes back in (had to drop it to remove my brand new dakota digital HDX cluster - it was bad from the factory and had to go back to DD for repair- like I said- nothing on this truck is ever easy).
thanks
1970 C-10 LWB "Blu"
Old 05-29-2018, 06:45 PM   #8
NC_John
NC_John's Avatar
I dremeled the u-joint some more and got the clearance I needed. Certainly not the best way to fix it but it worked.
1970 C-10 LWB "Blu"
Old 06-04-2018, 08:19 AM   #9
robnolimit
robnolimit's Avatar
Glad to hear it is fixed. Did you measure the shaft angles? I know using the dremel here seams a little out of place, but that is hot rodding.
Old 06-04-2018, 12:02 PM   #10
NC_John
NC_John's Avatar
I wanted to but it turned out to be a real pain with the inner fender already in. I was trying to get angles measured with the iphone and just didn't have enough room.
I installed a Turn One type II pump to work with it. I'm trying to sort out where to mount the remote reservoir and what I need to do for lines now. I'm very anxious to see how its going to work.... If everything works as it should and all my geometry is good, it should steer fantastic.
1970 C-10 LWB "Blu"
