05-11-2017, 09:34 PM | #1 |
Blue 67
Updating a LM7 for transplant
Hi: I bought a 2001 LM7 with 107000 miles on it to drop in place of the tired 350. I was wondering if there is any maintenance update that I should do before dropping the engine? Any seals or gasket that these engine might be prone to fail?
Also is there a mild and easy performance upgrade that I can do without affecting the reliability of the engine considering it has 107000 miles on it? Cam upgrade for example? It is going to be daily driver, nothing wild but we all enjoy a little more power. Thanks,
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
05-11-2017, 10:05 PM | #2 |
Re: Updating a LM7 for transplant
My lq9 had 107k on it when I put it in..I didn't worry bout it..these LS engines seem to run forever with little maintenance...some will change small items while its in the floor just for piece of mind..what are you putting it in?..I'm sure you've done your research but if not I doubt its just gonna drop in whatever you've got..what trans are you gonna put behind it?
05-12-2017, 12:30 AM | #3 |
Blue 67
I have been reading a lot about them. This is going to go to 79 Camaro with a rebuild TH350 with a shift kit. I also know that I need adaptor to mate engine and tranny together.
I have been reading these engine improve a lot with cam upgrade and simple off the shelves ad ons. I have never done any cam swap.
05-12-2017, 12:39 AM | #4 |
I don't have any specific recommendations for you, but one of the nice things about roller cams is that you don't have to worry about breaking them in, so that might make it a little more comfortable for you to take on.
05-12-2017, 12:56 AM | #5 |
Cam change in a ls is fairly simple...but seeing as to how you've never done it before get someone that has to give you a hand..they make hp easily with very little..a good cam and headers with a good dyno tune is awsome...check out btr cams..they have stage 1, 2, 3 setups..I'd recommend bying the swap kit if you go that route..check out utube for how they sound...I'm fixing to dump a stage 3 in my ls3..consider swapping the oil pump and a few gaskets and you will be good to go..but whatever you decide put it on a dyno..
05-12-2017, 06:23 AM | #6 |
I put an LM7 into my '80 C10 ('05 Tahoe engine, 139K miles) and used the BTR stg.1 cam, valve springs, and rocker arm bearing upgrade. While I was in the engine I changed the timing set and oil pump just for peace-of-mind. I also used an I6 Trailblazer torque convertor (2200 stall). Truck is very docile around town, but has really good response and power for when the need (?) arises. It also gets surprisingly good fuel economy for being a toy, if you can keep from getting too "eager' with the gas pedal ( restraint is an option ). Haven't seen a dyno yet, and I know there is more power on the table, but the truck runs so good as it is...
05-12-2017, 10:11 AM | #7 |
working on a 4.8 with a th350. i just picked up oil pump, belt and several gaskets but like mono said that is mainly for my "peace of mind" while I have it out.
05-12-2017, 03:11 PM | #8 |
Blue 67
Thanks guys. I have read that these engines are build to last. Also I have read since these are truck/suv engines and built with a high end torque, iron block with good flow stock aluminum heads, they respond well with a simple upgrades such as cam swap and a set of headers for use in muscle cars.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner Last edited by Nima; 05-13-2017 at 12:18 AM. |
05-12-2017, 08:27 PM | #9 |
Just be sure If you pull the oil pump there is a certian procedure to reinstall such as shimming the pump. You just cant bolt it on and go . Afew motors have been hurt by not doing it properly.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
05-17-2017, 01:27 PM | #10 |
I was under the impression that the shims are for double roller chains? Is there something that needs to be done to stock set ups?
05-13-2017, 11:23 AM | #11 |
best thing i can say is couple hunred in gaskets will its out go head and change the rear main seal, intake vavle cover gakets knock sensors and knonk sensor harness while the intake is off , my 4.8 the only leaks i have is the rear main and intake leaking i just stuck the thing in without changing anything
05-14-2017, 03:33 PM | #12 |
motor exploder
First thing I'd do is pull the valve covers and make sure it doesn't have Castech heads on it before spending a bunch of money on go fast parts.
https://www.jalopyjournal.com/forum/...ngines.933574/ http://speedtalk.com/forum/viewtopic.php?f=1&t=28519 http://www.gminsidenews.com/forums/f...r-heads-83436/ WELL documented problem and usually only shows up after 100k miles or so. My '05 GMC 5.3 started giving me issues after about 140k, smoking, using antifreeze with no visible leaks, then started running hot and sludgy oil. Anyway, I had previously installed a Comp Cams LSR 265 cam, long tube headers, Blackbear custom tune and a Yank 2600 stall converter - which really woke things up. After both of the heads cracked, I installed a set of Texas Speed PRC stage 2.5 heads to go along with the other stuff I already had and the thing came alive.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-14-2017, 11:46 PM | #13 | |
Blue 67
05-14-2017, 03:47 PM | #14 | |
CamMotion has drop in cams for the 5.3s which have given solid results with very little down side. If you want to be more aggressive the LS world has plenty of options. I would also do a Straub or CHE trunion upgrade. We just did the Straub trunion upgrade on a friend's C5, great customer service, good product. If you do a cam I would do a timing chain, lifters, push rods, and an oil pump. https://ls1tech.com/forums/dynamomet...hp-22rwtq.html Last edited by 93Polo; 05-14-2017 at 04:03 PM. |
05-15-2017, 06:58 PM | #15 |
driving is in my blood
With 107k I'd replace every gasket on the thing since its out and disconnected.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
