Old 05-18-2017, 04:38 PM   #1
Haru
Haru's Avatar
Th400 New or rebuild
Should I send it to the local shop for rebuild with some upgraded parts or buy a new one? The quote right now is $1250.00 to have me take it to them and get a rebuild with "upgrades" I'm assuming upgrades mean premium parts.
This will be used in my 71 with a 402, both the engine and trans are the originals. The engine will have mild work at some point (375HP) range.
Anyone here in/near Sacramento, CA that can do the work or perhaps I can even ship to someone? Or purchase new from you? Let me know thank you!
-71 C10 long bed, 402
-91 Camaro Z28, B2L 350
-96 Tahoe 2 door 2wd
-15 Tahoe LT
-16 Lexus RC 350 F sport
Haru is offline   Reply With Quote
Old 05-18-2017, 08:30 PM   #2
clinebarger
Re: Th400 New or rebuild
Building a 100% new TH400 costs a small fortune.
A stock rebuilt TH400 will handle 375 hp.
My base TH400 is $750, No core needed.
Includes......
4L80E Forward Hub (Stronger than a TH400 piece)
Rollerized Output
Dual Fed Direct Clutch
4L80E spirolock intermediate sprag retainer
Sonnax Boost Valve & PR spring
Pump gears
Borg Warner hi energy forward & intermediate frictions
Raybestos face grooved hi energy direct frictions
New lo/reverse band
All new bushings, seals & filter
Stock rebuilt converter, $100.
Upgrades if you plan on more power in the future....
4L80E 34 element sprag & direct drum, $200.
HD spirolock intermediate clutch snap ring, $16.
High rate direct clutch return springs, $25. Not Trans Go junk!
Reverse servo shim, $26.
190psi PR Spring
These upgrades will allow for up to 600 hp.
Above 600 hp, A billet Input shaft, Forward Clutch Hub & 215 psi PR spring are recommended. I do have some super low mileage Jaguar Cryo Treated input shafts living in 800hp trans brake cars......But with entry level Billet shafts costing around $200 now, Roll with billet if needed.
PM me if interested.
clinebarger is offline   Reply With Quote
Old 05-18-2017, 09:32 PM   #3
Haru
Haru's Avatar
Includes......
Rollerized Output
Pump gears
New lo/reverse band
190psi PR Spring
Awesome, thanks for the reply. I'll shoot you a PM momentarily.
-15 Tahoe LT
Old 05-19-2017, 11:29 AM   #4
truckdude239
truckdude239's Avatar
clinebarger is the one to go with !! he really knows his stuff
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
