07-05-2007, 10:22 PM | #1 |
chassis swap
Does anyone know if I can swap out the chassis from a 68 to a79? what I have is a 68 with a bent frame and I would like to put it on a 79 4X4 chassis. Can it be done? How much trouble? Thanks
07-05-2007, 10:38 PM | #2 |
Re: chassis swap
it can be done, i belive all you would have to if anything is to move the body mounts
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
07-05-2007, 11:36 PM | #3 |
Re: chassis swap
if you want you can practice on some of my junk. i'm sure if your at all handy it would be no problem but definitly not a bolt on deal
common sense isn't so common anymore |
07-05-2007, 11:40 PM | #4 |
Re: chassis swap
Nox exactly true.PM Mudder,he did this swap and has a awesome 67 shortbed using a 73-87 frame.Body mounts will need swapped,the frame shortened,or have a gap between the cab and bed,your choice and most likely a body lift.
07-06-2007, 01:46 AM | #5 |
Scrapper 1
Re: chassis swap
I was told the frame rails where to wide on the 1967--72 from the 1973--87 the 73-87 has a wider frame thats why the bumper and core suppot wont work unless you have a good amouth or welding time on your hands there are pleanty of 1968--72 frames laying around
