Old 05-16-2016, 02:32 PM   #1
NC_John
NC_John's Avatar
Control arm replacement options - CPP?
In disassembly of my 70 front end this past weekend, I found why the truck had a slight lean I could never get rid of (ended up cutting a coil to level it). I have a slightly bent lower control arm. It wasn't visible until I pulled out the control arm shafts.
Now I need to decide what to do. I was going to sandblast and paint these originals, rebuild everything with moog and put it back together.
I'm not sure I want to try to bend it back right. Should I try to find a good used replacement? Should I try to find a reproduction? Tubular a-arms aren't in the budget right now unless I go with the less expensive options.
For example, Summit (on their ebay site) has CPP 6372TCA-LKB control arms for $326/pr. I could run those lowers with my stock uppers for now.
Does anyone have any first hand experience with these? Is there a better alternative? (I'll go hotchkis if we hit the powerball) I loathe CPP and their "customer service shenanigans" but am not familiar with the others out there and don't know if they are any good.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 05-16-2016, 03:06 PM   #2
sprint_9
sprint_9's Avatar
Re: Control arm replacement options - CPP?
Your cheapest option would be to head to a salvage yard and get one there. I wouldnt try to bend it back. I would just stay stock for the money, aftermarket in my opinion is if your trying to lay frame or building a pro touring truck.
sprint_9 is offline   Reply With Quote
Old 05-16-2016, 03:15 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I bought the CPP stock style arms (I got mine from summit too)
http://www.summitracing.com/parts/cl...del/c10-pickup
http://www.summitracing.com/parts/clp-6372scal
When I pulled my suspension apart for the 4/6 drop I found my upper and lower control arm bushings had a fair amount of wiggle. It was expensive, but I didn't have time to strip, clean, and rebuild my stock ones with new bushings (not cheap either.)
They appear to be just as heavy as stock. It was tricky getting the lower shock bolt in, but it's tricky with the factory ones too.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-16-2016, 08:26 PM   #4
NC_John
NC_John's Avatar
Affirmative on the pro-tour, however, I have a short-bed frame I am going to upfit for that. Yeah, I didn't want to try to bend it back and deal with a front end that can't be properly aligned later.
1970 C-10 LWB "Blu"
Old 05-16-2016, 08:29 PM   #5
NC_John
NC_John's Avatar
My uppers are in good shape. I guess if their lowers are of similar quality to the originals, I'll just go that way and buy the pair. I bought new moog control arm shafts so might use those instead of the ones they send.
Thanks!
1970 C-10 LWB "Blu"
Old 05-16-2016, 11:15 PM   #6
67ChevyRedneck
They come assembled, which is another reason why I bought them. If you already have the shafts and new bushings and are OK with swapping them, I would go with some used arms and save a pile of $.
Jesse James
Project "On a Dime"
Old 05-17-2016, 08:27 AM   #7
NC_John
NC_John's Avatar
Yeah, but I'd have to hunt down and find a good one (and hope its not tweaked either- mine was very hard to see). Then sandblast and paint (both sides of the pair)... that's three trips and a bunch of money right there...
Its pretty appealing to say screw it and get the pair of new CPP ones. Nice, straight, clean, powdercoated and ready to bolt on!
1970 C-10 LWB "Blu"
Old 05-17-2016, 09:07 AM   #8
'68 Newtricks
'68 Newtricks's Avatar
just make sure to check the ball joints before you assemble anything
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-17-2016, 09:30 AM   #9
NC_John
NC_John's Avatar
you mean to make sure the factory ball joints fit? I was relieved all my '70 parts fit the CPP drop spindles. With the runaround you get from those guys I was nervous it was going to be a cluster.
1970 C-10 LWB "Blu"
Old 05-17-2016, 10:59 AM   #10
fwayne
fwayne's Avatar
Hmmm. I'm not sure how these would be considered cost effective. Convenient absolutely, but I just rebuilt my entire front end, upper bushings, lower bushings, upper and lower ball joints outer ties rods, and idler arm for less than $250 using all MOOG parts.(rock auto) It took me 6 hours. It won't take any more tools to perform vs replacing them with new units. (other than a grinder/ air hammer if you still have factory riveted top ball-joints)
I would suggest finding a salvage arm and rebuilding them if cost is a factor.
1970 GMC Stepside Short
Gone...Factory 350 V8
Now...4.8L LS
fwayne is offline   Reply With Quote
Old 05-17-2016, 11:16 AM   #11
fwayne
fwayne's Avatar
I found an easy fix on that tight shock mount. Just use a crescent wrench and slightly bend the outer mounting tab out. the shock will fall in place no trouble, and when tightened the mount will return to where it is supposed to be.
Also how do you like your KYB shocks? I have the mono tube style and love them.
Now...4.8L LS
Old 05-17-2016, 11:37 AM   #12
67ChevyRedneck
They seem to work well. They came with the ECE drop kit I bought.
Considering the rear shocks were still the originals from 1967... that was a nice improvement.
Jesse James
Project "On a Dime"
Old 05-17-2016, 01:06 PM   #13
NC_John
NC_John's Avatar
The cost effective part IS the convenience. This is saving me hunting and running around trying to find a used straight replacement )and probably having to crawl under a truck at the boneyard (during a week of steady rain), then finding somewhere to get them sandblasted and then painted. Time is money and I have enough other stuff going on that this seems a good trade.
If I was retired and had the time, I might be more interested to go the hard way but I want the downtime for this upgrade project minimal. The longer it is apart, the more stuff I find that I should do while it is apart and the more the project snowballs.
1970 C-10 LWB "Blu"
