Old 06-20-2018, 10:57 PM   #1
hahnn6
Where is the partial VIN on my 1971 Blazer engine block
Hey, my engine pad only has V0122TBG stamped on it, which I was able to find that TBG = 1971 350ci "Conveab" (not sure what that means), AT, 255hp, for a K-10 to 2500.
My question is, some websites say that the partial VIN (making it "matching numbers") was moved around in different years. Does anyone have a 71 Blazer that they can point me to a detailed specific location, ideally with pictures? Mine is going in for rebuild and it's caked in grease, any detailed area to look would be great. Thank you
hahnn6 is offline   Reply With Quote
Old 06-20-2018, 11:02 PM   #2
JackB
Re: Where is the partial VIN on my 1971 Blazer engine block
Trucks did not get stamped with a partial vin like the passenger cars did. The engine only has the assembly date stamped on the pad which you have already discovered.
JackB is offline   Reply With Quote
Old 06-20-2018, 11:20 PM   #3
JackB
To add a little more..Although there is no way to be certain that the engine is original one thing to look at is the assembly date of the engine vs. the build date of the truck. Generally they are within a few weeks of each other. For example the 71 Blazer I am working on now which I am certain has the original engine was assembled 8/70 with an engine that was assembled on 7/30/70. TBG is the correct code for a 1971 350 w/AT
Old 06-20-2018, 11:34 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a recent related thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751844
Old 06-21-2018, 01:06 PM   #5
hahnn6
great, good to know thanks for all the info guys! My glovebox still has the information tag, it was covered with masking tape under someone's paint job they did on the dash... that was nice of them!
Old 06-21-2018, 05:41 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Nice options, lets see some pics!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-24-2018, 03:08 PM   #7
hahnn6
Thanks for all the info guys! I yanked the drivetrain and the trans/tcase have been rebuilt professionally, and waiting to be installed again... fast turn around from the shop, they had it only three days! The engine is getting rebuilt currently. I'll be doing a write up soon on putting in an 87 Blazer fuel tank (baffled) to run EFI in it, does anyone know if there's a good write up already? I didn't see one in my hasty search. Also, the 87 sending unit says its 95ohms and ours is 90ohms (right?) does that 5ohm difference jack with the fuel gauge at all?
I'm going to have to power wash the several inches of caked grease/dirt in the engine bay while the drivetrain is out, any suggestions on how to get it off besides scraping and power washing?
I'll get some better pics of the truck as I go along with it too!
Old 06-24-2018, 06:48 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If you want to preserve the engine code on the block ask the machine shop to forgo decking the block if possible or the code will be gone.
Pressure wash and oven cleaner to tackle the grease.
Any chance you want to sell the neck from the original fuel tank? I'll take it if so or could trade some blazer parts.
Are the tow hooks still there?
Old 06-25-2018, 08:12 AM   #9
hahnn6
I will call the builder today thank you! It does have the tow hooks, and even the behind the seat spare tire carrier! I'll let you know regarding the filler neck, If I don't use it for the build, I'll PM you
Old 06-25-2018, 03:49 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet! Good luck w the build.
