02-18-2017, 10:33 PM | #1 |
Torque converter clutch solenoid
Hi guys having difficulty finding an answer for this one. My truck is an 84 c10 350/700r4. Well the thing seems like when it is locking up it vibrates until I hit the brakes. I was told it was the tcc solenoid, so I dropped the pan and bought a new one from the parts store. My one that is in my truck is a single wire and the replacements are 2 wire. Will a two wire work? Looks like maybe you have to ground the extra wire out in the case? Thanks for the help in advance!
02-19-2017, 11:05 PM | #2 | |
Re: Torque converter clutch solenoid
02-20-2017, 06:46 AM | #3 |
Thanks, that's kind of what I figured just wanted to make sure. Do you foresee that being my vibration issue? I think I've pretty much got it narrowed down to that or a bad converter.
02-20-2017, 07:02 AM | #4 |
My money is on a bad converter
02-20-2017, 01:02 PM | #5 |
Were the originals a light green color? If so it may be bad, if it's the original converter.
02-20-2017, 08:58 PM | #6 | |
It's probably converter shudder (The converter clutch itself), Have a local converter builder install a Woven Carbon Clutch in yours.......If this was a 30 spline input, You could use a off the shelf '98-'01 298mm 4L60E converter, But a '85 700R4 is 27 spline. |
