Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-25-2008, 06:28 AM   #1
Prerunner1982
Prerunner1982's Avatar
spark plug
How do you get the middle plug on the driver's side out? I cant get the plug socket on it. Couldnt get a box end wrench on it..
What is the trick?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-26-2008, 05:21 PM   #2
Tink
Tink's Avatar
Re: spark plug
I've used a spark plug socket and a 3/4 wrench on the end of it with my first gen S10s...
On my 00 Blazer, I can put the socket on the plug first, then the extension with U-joint or a wobble extension.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 02-27-2008, 02:01 AM   #3
Prerunner1982
Re: spark plug
Maybe I am just not holding my head and the right angle and my tongue in the right direction..
I cant even get a socket on the spark plug, to put a wrench or a swivel on it.
Jon
Oklahoma Roll Call
Old 02-27-2008, 07:33 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: spark plug
Disconnect the linkage. Lock the steering wheel before you disconnect the linkage!!
Did you remove the wheels? It's easier to change the spark plugs if you reach through the wheel wells.
Option 2: buy this tool used on headers
Option 3: cut a socket down to make the same tool above.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-28-2008, 07:44 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
Re: spark plug
I have that one. its handy for headers. but foer the 4.3 S10s I have this one.http://buy1.snapon.com/catalog/item....re&dir=catalog
68C15 is offline   Reply With Quote
Old 02-29-2008, 03:35 AM   #6
Prerunner1982
Re: spark plug
Thats what I am talking about..... even talks about the exact problem I am having... but for $31 for 1 socket... I might try the steering shaft first..
But then again... how much is my time worth?
Jon
Oklahoma Roll Call
Old 03-04-2008, 03:11 AM   #7
Kurt L
Kurt L's Avatar
Re: spark plug
i broke the motor mount loose on my 2001 blazer then got a long pry bar, put my wife to pushing down on the bar to lift engine to clear the steering shaft,went thru the wheel well pretty easy that way.
Kurt L is offline   Reply With Quote
Old 03-04-2008, 10:01 PM   #8
Prerunner1982
Re: spark plug
I am going to try and disconnect the steering shaft. It looks to be pretty easy..
Jon
Oklahoma Roll Call
Old 03-05-2008, 07:19 AM   #9
68C15
blood type; Retumbo
68C15's Avatar
Re: spark plug
if it has an air bag BE SURE to lock the wheel before you pull the shaft.
