09-08-2016, 11:24 PM | #1 |
88 Stepside. Ls swap, daily driver.
Traded an 84 GMC Sierra for this truck. When the trans started to slip several friends suggested we could LS swap cheaper than a trans. I bought an Avalanche for $750, kept, engine/trans, wire harness, exhaust, fuel pump and some small parts. Sold remainder for $805.
Harness is reworked stock harness, initially I used the Avalanche fuel pump until it died. Now I have a stock replacement for a 96 Vortec truck. Engine mounts are Car Shoppe, 1.5" setback. I moved the trans crossmember back the same amount. Air intake is a cheap Ebay piece for the new body style trucks. I ran it with open cats at first then welded up the exhaust with mandrel bends. I got the bends as scrap cut offs from a 2010 Camaro. I bought v bands, 4 straight pieces and 2 Dynomax bullets. I'm still working on it as I drive it. Still to come are getting the gauges to work, and clean up the wiring. I have plans of doing some budget mods to the engine, hopefully swapping to a 4L80 and a 14 bolt.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
09-08-2016, 11:29 PM | #2 |
Re: 88 Stepside. Ls swap, daily driver.
Exhaust pics. A friend and I started with a pile of scrap and cut and pasted. Some how the tips moved between the truck and the table. Not paying attention, I fully welded one side, and discovered the mistake. I'd like them closer.
09-08-2016, 11:52 PM | #3 |
The front was lowered with Craigslist springs. The rear, another friend wanted a 6" drop, but had dropped hangers. I swapped with him and help with his drop. To grind off the rivets, I used a36 grit flap wheel on an angle grinder. I made a bracket to hold my e brake cables.
09-08-2016, 11:57 PM | #4 |
That brings it up to date. Newest projects not related to engine swap was fixing damage from hitting a deer. I pulled the clip off a 4wd Sub, used the driver's fender, core support, grill, and bumper. Also swapped on the tow hooks. Next project is replacing the door hinges.
09-11-2016, 02:52 PM | #5 |
i followed your build on mark's facebook page. nice to see you on here!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
09-12-2016, 10:48 PM | #6 |
Thanks! Mark is one the best guys in this hobby. He helped a lot, and gave a lot of insight into this.
09-12-2016, 10:49 PM | #7 |
09-28-2016, 10:58 PM | #8 |
Fuel lines. There are a million ways to do it. I couldn't get the return line's braided section off, and broke a line wrench in the process. So I went with a fuel line repair kit and patched an adapter of sorts. After some research this is the permanent method I used.
Russell LS fuel rail fitting, -6 AN, -6 AN couplers, and -6 AN to o-ring adapters. Not pretty, but it is functional.
08-07-2019, 12:03 AM | #9 |
Realized it's been nearly three years since I updated this. Truk has a new yard mate, a 00 Tahoe Z71, has had a trans swap and has seen passes at 3 local tracks, Jakes's in Moulton Al, Baileyton, and Huntsville.
12-07-2019, 11:04 PM | #10 |
Newest addition swapped to a fleetside bed.
12-07-2019, 11:59 PM | #11 |
Right on
12-08-2019, 12:09 AM | #12 |
Cool truck. Nice work!
07-03-2020, 10:01 PM | #13 |
Your truck keeps getting cooler as you go. Now that you've done all your sheet metal fixes and tweaks is there one color of paint in the cards?
11-08-2020, 08:51 PM | #14 |
do you remember what size tires were on the steelies? they look righteous, and my truck needs tires on the same era rallys.
