Old 10-02-2019, 01:32 PM   #1
mike88a
mike88a's Avatar
89 tbi egr/headers?
I have an 89 tbi going in to my 87. I want to add headers in the most cost effective way possible. What do I do about the egr?
mike88a is offline   Reply With Quote
Old 10-02-2019, 01:34 PM   #2
mike88a
mike88a's Avatar
89 tbi egr/headers?
Dropping an 89 tbi motor into my 87 and want to add headers int eh most cost effective way I can. What do I do about the egr?
Old 10-02-2019, 01:55 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
Re: 89 tbi egr/headers?
There aren't any egr tubes on 87-95 engines. The valve gets it exhaust source from the exhaust crossover in the intake manifold.
There may be air injection tubes in the exhaust manifolds. Any chance that's what you see?
95 S_Trucker is offline   Reply With Quote
Old 10-02-2019, 03:15 PM   #4
SCOTI
SCOTI's Avatar
The EGR is part of the ECM loop so you need to keep it or have it deleted by tuning (new chip). Whatever headers fit your chassis will get the job done. You just need an o2 port near the collector.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-02-2019, 03:19 PM   #5
mike88a
mike88a's Avatar
Possibly. I just keep seeing headers that say for models without egr.
Old 10-02-2019, 04:37 PM   #6
mike88a
mike88a's Avatar
Perfect. Thanks
Old 10-02-2019, 04:38 PM   #7
mike88a
mike88a's Avatar
Got it all sorted out. I was thinking about it all wrong.
Old 10-02-2019, 05:04 PM   #8
sweetk30
sweetk30's Avatar
if full length headers its best to swap to a heated o2 sensor . lots of threads on this for your reading .
i my self dont care for headers . lots of extra heat and noise under the hood .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-02-2019, 05:58 PM   #9
SCOTI
SCOTI's Avatar
Heat for sure. Mine are ceramic coated & still put off some serious temps. I haven't had any issues on the noise level though. Are they louder than cast iron manifolds? Yep. But I don't notice any difference w/the hood shut. I also ground the head flanges true & made my own 3/8" thick collector flanges so zero leaks vs. the repeat leaker on my exhaust manifolds (pass side).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-02-2019, 06:49 PM   #10
mike88a
mike88a's Avatar
Thanks for the help. It is my sons build. We are going mid length headers with a o2 bung in the collector so I think a regular o2 sensor will work. The noise is part of the fun and the heat is not that bad. But that is the beauty of our trucks to each his own. I truly appreciate your assistance!
Old 10-02-2019, 06:51 PM   #11
mike88a
mike88a's Avatar
I know I did ceramic coated in my 67 to help with the heat issue but i don't think it made any difference. All in all if you keep the wires away its not that bad.
Thanks for your input!
Old 10-03-2019, 07:38 AM   #12
Stormin08
Stormin08's Avatar
good deal, i just sold a set with air tubes ( capped), and bought the non air tube versions.
Stormin08 is offline   Reply With Quote
Old 10-03-2019, 02:29 PM   #13
SCOTI
SCOTI's Avatar
I had my chip/tune done w/the air pump option deleted since there wasn't one. But mine was/is a 1TON dually & didn't have CATs either.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2019, 06:56 PM   #14
71gmcC15
71gmcC15's Avatar
I. On my 94 I deleted the egr and 02 sensor with out tuching the computer and it never made a difference. I have long tube headers and no cats . Same amount of power. Runs the exact same. And never had a problem. I also got rid of the e vap canister. You can tell where I live there is no inspection
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
