Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-29-2018, 05:12 PM   #1
jrusher
Replacing floor braces, rockers etc
So just in the middle of an ls swap on my 65 and the more I look at my front cab floor supports and rest of rot the more I realize how bad an unsafe it is . I picked this truck up in Oklahoma last spring .
Anyways this is what I’m dealing with few pics attached . The front cab mount supports are totally gone an collapsing the rears could be patched in . Needs inner outer rockers , kick panels, floor braces, probably A pillar pieces and floor pans . The drivers side foot area rot goes up quite aways not sure if there’s patch panels for these areas ?
So thought about a complete floor but don’t really want to pull cab so I might just tackle it with cab on frame an lift one side at a time an do The floor braces. I know this is a ton of work I’ve done some floor work on my Chevelle and it wasn’t a lot of fun but now is the time to tackle this before I put me engine etc back in.
Any tips on what to tackle first would be greatly appreciated
This is what I was thinking of doing first
- cross brace cab
- a pillar patches if needed
- then front floor brace/support complete right to cab mount
- rear cab floor support
- floor pan
- kick panel
- then work back towards rockers
jrusher is offline   Reply With Quote
Old 03-29-2018, 05:28 PM   #2
jrusher
Re: Replacing floor braces, rockers etc
Heres a few of the floor supports , the fronts need total replacement the rears i could probably patch them in. Have to patch behind front wheels on firewall/toe board area as well
Old 04-02-2018, 05:01 PM   #3
72HuggerK20
Just curious why you don't want to pull the cab? It's not that hard. There's like 3 wiring connections, take the master cylinder and the steering column off, and 4 bolts. Takes like 2 hours. I did the whole floor on my 72, and it was definitely a good decision. I feel a lot better about it now.
72HuggerK20 is offline   Reply With Quote
Old 04-02-2018, 05:44 PM   #4
jrusher
After taking to a few different body guys they all suggested to keep as much of the factory floor as possible an not replace whole floor. Most of my floor is solid except foot area and braces. I’m gonna try lift one side at a time first an see how that goes for brace replacement if needed I”ll pull cab . I have a 2 post lift in my shop which makes things so much easier
Old 04-02-2018, 05:54 PM   #5
mongocanfly
mongocanfly's Avatar
with a 2 post lift then pulling the cab for repair should be a nobrainer...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-02-2018, 09:00 PM   #6
72HuggerK20
Replacing the floor entirely with an OEM-style part is definitely better than patching here and there. There will be no rust, no random weld seams to cause distortion and stress points, and it is easier to install. Not to mention that it takes half the time to do.
Old 04-02-2018, 09:35 PM   #7
cornerstone
cornerstone's Avatar
What he said.^^^ Plus you really need new bushings. It sounds like its much harder to replace the entire floor with one piece but its not! the new floor is under 500. when its on sale and the labor time will be less than half of how much time it will take to "patch" your floor.
cornerstone is offline   Reply With Quote
Old 04-02-2018, 10:05 PM   #8
mongocanfly
^^^×3^^^
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-02-2018, 10:32 PM   #9
slowcpe
slowcpe's Avatar
My floor isn’t as bad as that on my ‘67 and I’ve been told by many to just replace the entire floor. Seems way easier for me.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 04-02-2018, 10:37 PM   #10
jrusher
I just finished sandblasting bunch of floor an toe boards an I’m going to grab a one piece floor tomorrow. There $1100 up here if I bought all the pieces I need separately would be around $800 . Cab is coming off
Old 04-02-2018, 10:57 PM   #11
cornerstone
Old 04-03-2018, 10:54 PM   #12
jrusher
Grabbed floor today. Braces cab up an off with it
Old 04-03-2018, 11:24 PM   #13
mongocanfly
sweet looking floor pan. ...I don't think you'll regret it...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-04-2018, 12:36 AM   #14
jrusher
Ya it’s a dynacor hopefully fits good . Almost got the old one out
Old 04-04-2018, 10:35 AM   #15
slowcpe
slowcpe's Avatar
Very nice! I can't wait for the day the floor gets replaced in my '67.
Ryan
Old 04-05-2018, 02:03 AM   #16
jrusher
What does a guy use in between cab/floor flanges besides weld on primer ? Looked like there was seam sealer inside cab on floor an the firewall joint ?
Old 04-05-2018, 07:47 AM   #17
72HuggerK20
If there was seam sealer originally, it needs it again. I'd also spray the entire underside of your new floor with some sort of undercoating.
Old 04-05-2018, 09:33 AM   #18
jrusher
I didn’t see any sealer in between the flanges only inside the cab at the tranny tunnel area there was a bead layed on top of the joint. Just wanna make sure . I’m ready to mount up new floor but have to sand inside cab while it’s on it’s back first
Old 04-05-2018, 11:00 AM   #19
mongocanfly
the seam sealer on mine was put on after it was assembled....you wouldn't want it between the joints if you have to weld them..that's where the weld thru primer comes in...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-05-2018, 11:01 AM   #20
72HuggerK20
I'd probably at least seam seal it after it's welded in from both the top and bottom sides. Also spray the insides of your new rockers and cab corners with undercoating before you weld them on too. Also some cavity wax with a wand kit helps prevent corrosion.
Old 04-05-2018, 11:44 AM   #21
jrusher
Right on that’s what I figured just wanted to make sure . Thx
Old 04-06-2018, 02:37 AM   #22
mongocanfly
keep in mind seam sealer needs to at least have a coat of primer put down first...it doesn't need to be put dtm
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-06-2018, 04:13 PM   #23
jrusher
Was hoping to put floor in place an tack it up but have to sand inside of cab and fix rust/holes in roof outer/inner skin from an old antenna. Tempted to pop a perfect skin off a spare roof I have
Old 04-08-2018, 04:09 PM   #24
CUDA8U
CUDA8U's Avatar
i would get the whole cab acid dipped and go from there.
CUDA8U is offline   Reply With Quote
Old 04-08-2018, 04:51 PM   #25
jrusher
Not doing a restoration.
Keeping the old exterior paint etc . Inside will be solid after this . I’ve gone through whole drivetrain , suspension, ps, pb etc . Just built a ls for it as well
